[GRASSLIST:5116] RE: Installation Problem
Try --with-postgres-includes=no
I got this problem also a few weeks ago. The below worked for me. I'm not sure you are running into the same issue as me however.
Can you paste the exact error message in your email?
-Daniel Gélinas
-----Original Message-----
Sent: Thursday, November 28, 2002 7:45 PM
To: grasslist@baylor.edu
Subject: [GRASSLIST:5111] Installation Problem
Hello list,
I'm attempting to install GRASS 5.0.0, and I'm running into a wall. I
can't seem to convince the ./configure script that I don't want support
for PostgreSQL. I tried --without-postgres, --with-postgres=no,
--without-pgsql... nothing seems to work. Can someone give me an idea
as to what I'm doing wrong?
Thanks for your help.
Doug Gorley
That won't help; it will just generate an error.
