[GRASSLIST:5119] Sound reflection and refraction
Has anybody ever tried to interpolate sound (==> noise) in a general GIS? I only mean 2D interpolation. I know 2D is a big compromise but it has to be done for my school assignment and at this level I do not intend to use a 3D technique.
How would you treat the spread of a signal from a source r.cost is not a very good solution because of the refraction (picture the emission and imission points on the opposite sides of a building).
What about the reflection from objects?
Ideas and comments are welcome.
Miha Staut
_________________________________________________________________
Tired of spam? Get advanced junk mail protection with MSN 8. http://join.msn.com/?page=features/junkmail
you could use an aspect map in conjunction with a slope map, so that you know the normal 3D-versor to the surface, and hence calculate the main reflection path (beware the 0° orienation of the aspect map).
Since you are working in 2D, I assume that you have a raster map defining the edges of buildings.
BTW, how do you want it to work? raster maps based or vector-like?
regards,
RafDouglas CTC
RafDouglas Candidi Tommasi Crudeli
ct@ehleng.com
"To know, to will, to dare, to be silent."
On Sat, Nov 30, 2002 at 08:26:11PM +0000, Miha STAUT wrote:
technique.
you may read this paper:
Geomatics WorkBooks No 2 - 2001:
Biagi L., Brovelli M.A., Scuratti M.
Enviromental noise modeling within an open source GIS
http://geomatica.ing.unico.it/cgi-bin/workbooks.cgi?pag=abs2&ind=2
Markus Neteler
From - Mon Nov 4 08:07:06 2002
X-UIDL: 3d0f08730000723e
X-Mozilla-Status: 0001
X-Mozilla-Status2: 00000000
Received: from fw (virscan [139.17.1.10])
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id SAA03916;
  Thu, 31 Oct 2002 18:12:16 +0100 (MET)
Received: from waylon.baylor.edu ([129.62.3.228]) by fw; Thu, 31 Oct 2002 18:12:16 +0100 (MET)
Received: from ccis01.baylor.edu ([129.62.1.18]) by waylon.baylor.edu with Microsoft SMTPSVC(5.0.2195.4561);
   Thu, 31 Oct 2002 11:12:13 -0600
Received: from localhost (localhost [127.0.0.1])
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id LAA1507444;
  Thu, 31 Oct 2002 11:11:53 -0600 (CST)
Received: from FS-EXCHANGE1.baylor.edu (flopsy.baylor.edu [129.62.3.249])
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id LAA1507404
  for <GRASSLIST@listproc.baylor.edu>; Thu, 31 Oct 2002 11:11:52 -0600 (CST)
Received: from waylon.baylor.edu ([129.62.3.228]) by FS-EXCHANGE1.baylor.edu with Microsoft SMTPSVC(5.0.2195.4561);
Received: from willie.baylor.edu ([129.62.3.227]) by waylon.baylor.edu with Microsoft SMTPSVC(5.0.2195.4561);
Received: from mx1.un.org ([157.150.197.100])
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002103111115104552
for <GRASSLIST@baylor.edu>; Thu, 31 Oct 2002 11:11:51 -0600
Received: from un-mailhub-02.un.org (un-mailhub-02.un.org [157.150.197.20])
  by mx1.un.org (8.11.0/8.11.0) with ESMTP id g9VHHaK14654
  for <GRASSLIST@baylor.edu>; Thu, 31 Oct 2002 12:17:36 -0500 (EST)
Subject: [GRASSLIST:4863] Moran's I
To: GRASSLIST@baylor.edu
X-Mailer: Lotus Notes Release 5.0.7 March 21, 2001
Message-ID: <OF3E3A1F9C.BAE38577-ON85256C63.005E6EDD@un.org>
Date: Thu, 31 Oct 2002 12:11:49 -0500
X-MIMETrack: Serialize by Router on un-mailhub-02/UNO(Release 5.0.8 |June 18, 2001) at
31/10/2002 12:11:50 PM
MIME-Version: 1.0
Content-type: text/plain; charset=us-ascii
X-OriginalArrivalTime: 31 Oct 2002 17:11:52.0190 (UTC) FILETIME=[9B1939E0:01C28100]
Sender: owner-GRASSLIST@baylor.edu
X-Listprocessor-Version: 8.2.10/991025/16:55 -- ListProc(tm) by CREN
Status: O
Content-Length: 755
Lines: 23
Dear All,
I am experienced with GIS but new to GRASS and LINUX. I have installed
GRASS 5.0.0 on my machine using the precompiled binaries for Linux (I am
using RedHat 8.0) I cannot use the command r.moran. Grass cannot find it. I
have looked myself and there is nothing on the machine with this name o any
similar one. The documentation and command list includes this command for
grass 5.0.0.
What is wrong here? Could that be that the binary is missing this and
possibly other files?
Thank you!
Tiberiu Alexandru CODILEAN
SSA GIS Consultant
United Nations, HQ, Cartographic Section, Room L-172
New York, NY 10017, U.S.A.
Tel.: +1 917 367 3274
Fax: +1 212 963 3742
E-mail: codilean@un.org
From - Mon Nov 4 08:07:11 2002
X-UIDL: 3d0f087300007241
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id SAA07633;
  Thu, 31 Oct 2002 18:36:03 +0100 (MET)
Received: from waylon.baylor.edu ([129.62.3.228]) by fw; Thu, 31 Oct 2002 18:36:01 +0100 (MET)
   Thu, 31 Oct 2002 11:35:33 -0600
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id LAA1512305;
  Thu, 31 Oct 2002 11:35:26 -0600 (CST)
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id LAA1512185
  for <GRASSLIST@listproc.baylor.edu>; Thu, 31 Oct 2002 11:35:24 -0600 (CST)
Received: from escudo.nhh.no ([158.37.96.28])
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002103111352215566
for <GRASSLIST@baylor.edu>; Thu, 31 Oct 2002 11:35:23 -0600
Received: from nhh.no (colon.nhh.no [158.37.98.22])
  by escudo.nhh.no (8.12.2/8.12.2) with SMTP id g9VHZLY8084183;
  Thu, 31 Oct 2002 18:35:21 +0100 (CET)
Received: from wolf.uib.no ([129.177.30.18])
        (SquirrelMail authenticated user georb)
        by webmail.nhh.no with HTTP;
Message-ID: <41372.129.177.30.18.1036085721.squirrel@webmail.nhh.no>
Date: Thu, 31 Oct 2002 18:35:21 +0100 (CET)
Subject: [GRASSLIST:4864] Re: Moran's I
To: <codilean@un.org>
In-Reply-To: <OF3E3A1F9C.BAE38577-ON85256C63.005E6EDD@un.org>
References: <OF3E3A1F9C.BAE38577-ON85256C63.005E6EDD@un.org>
Cc: <GRASSLIST@baylor.edu>
Reply-To: Roger.Bivand@nhh.no
X-Mailer: SquirrelMail (version 1.2.7)
MIME-Version: 1.0
Content-Type: text/plain; charset=iso-8859-1
Content-Transfer-Encoding: 8bit
X-OriginalArrivalTime: 31 Oct 2002 17:35:24.0398 (UTC) FILETIME=[E4D710E0:01C28103]
Status: O
Content-Length: 1889
Lines: 49
Alexandru Codilean wrote:
Dear All,
it. I have looked myself and there is nothing on the machine with this
name o any similar one. The documentation and command list includes this
command for grass 5.0.0.
In fact the manual page is still distributed with the 5.0.0 source, but no
r.moran code is present. The code was written by Jo Wood, and the manual
page is dated 1994. My guess would be that the code has not been
maintained for some time, is maybe in the 4.2.1 source tarball, may be in
the 4.3 tarball, but hasn't migrated to 5.0.0. This is because the change
to 5.0.0 involved the replacement of numeric 0 by a NULL not available
value (since numeric 0 can be a useful numerical value), and migration to
floating point rasters for data of the kind returned by a local Moran's
I_i. If you need Moran's I, one posibility is the interface to R described
on the geostatistics section of the website. In R, Moran's I and local
Moran's I_i are in contributed package spdep. If you need specific help,
contact me off the list, and we can work something out (doing tests on
local Moran's I_i is not so easy - there is a saddlepoint approximation
function in spdep).
Roger
Thank you!
SSA GIS Consultant
Roger Bivand
NHH, Breiviksveien 40, N-5045 Bergen, Norway
(travelling but still accessible)
From - Mon Nov 4 08:07:15 2002
X-UIDL: 3d0f087300007253
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id XAA22390;
  Thu, 31 Oct 2002 23:23:17 +0100 (MET)
Received: from waylon.baylor.edu ([129.62.3.228]) by fw; Thu, 31 Oct 2002 23:23:16 +0100 (MET)
   Thu, 31 Oct 2002 16:23:14 -0600
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id QAA1074465;
  Thu, 31 Oct 2002 16:22:18 -0600 (CST)
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id QAA1074749
  for <GRASSLIST@listproc.baylor.edu>; Thu, 31 Oct 2002 16:22:15 -0600 (CST)
Received: from web10102.mail.yahoo.com ([216.136.130.52])
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002103116221414844
for <GRASSLIST@baylor.edu>; Thu, 31 Oct 2002 16:22:14 -0600
Message-ID: <20021031222213.94192.qmail@web10102.mail.yahoo.com>
Received: from [128.107.253.39] by web10102.mail.yahoo.com via HTTP; Thu, 31 Oct 2002 14:22:13 PST
Date: Thu, 31 Oct 2002 14:22:13 -0800 (PST)
Subject: [GRASSLIST:4865] GRASS multiple language support
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-OriginalArrivalTime: 31 Oct 2002 22:22:15.0027 (UTC) FILETIME=[F72CA430:01C2812B]
Status: O
Content-Length: 300
Lines: 17
I may not read all GRASS document, but I cannot find
if GRASS support multiple languages, such as
Chinese/Japanese.
Can anyone help me on that.
Thanks a lot,
Fox
Do you Yahoo!?
HotJobs - Search new jobs daily now
http://hotjobs.yahoo.com/
X-UIDL: 3d0f087300007254
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id XAA25739;
  Thu, 31 Oct 2002 23:46:33 +0100 (MET)
Received: from waylon.baylor.edu ([129.62.3.228]) by fw; Thu, 31 Oct 2002 23:46:32 +0100 (MET)
   Thu, 31 Oct 2002 16:46:31 -0600
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id QAA1082454;
  Thu, 31 Oct 2002 16:46:25 -0600 (CST)
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id QAA1082521
  for <GRASSLIST@listproc.baylor.edu>; Thu, 31 Oct 2002 16:46:23 -0600 (CST)
Received: from bobcat.ncia.net ([207.141.177.10])
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002103116462214703
for <GRASSLIST@baylor.edu>; Thu, 31 Oct 2002 16:46:23 -0600
Received: from Omnit (ncia-lfp-181.ncia.net [206.243.130.181])
  by bobcat.ncia.net (Postfix) with SMTP id 0DB5E38376
  for <GRASSLIST@baylor.edu>; Thu, 31 Oct 2002 17:46:21 -0500 (EST)
Reply-To: cbsled@ncia.net
Date: Thu, 31 Oct 2002 17:42:48 -0500
To: <GRASSLIST@baylor.edu>
In-Reply-To: <41372.129.177.30.18.1036085721.squirrel@webmail.nhh.no>
Subject: [GRASSLIST:4866] copying regions between systems
X-Mailer: MR/2 Internet Cruiser Edition for OS/2 v2.30a/30
Message-Id: <20021031224621.0DB5E38376@bobcat.ncia.net>
X-OriginalArrivalTime: 31 Oct 2002 22:46:23.0157 (UTC) FILETIME=[5653BE50:01C2812F]
Status: O
Content-Length: 287
Lines: 8
Can I simply tar up the region's dir in the database and copy it to another machine?
Or is there more to it than that, and if so, what?
TIA
Carl Brown cbsled@ncia.net
X-UIDL: 3d0f087300007256
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id AAA04970;
  Fri, 1 Nov 2002 00:52:05 +0100 (MET)
Received: from waylon.baylor.edu ([129.62.3.228]) by fw; Fri, 01 Nov 2002 00:52:03 +0100 (MET)
   Thu, 31 Oct 2002 17:52:01 -0600
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id RAA1096435;
  Thu, 31 Oct 2002 17:51:54 -0600 (CST)
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id RAA1096472
  for <GRASSLIST@listproc.baylor.edu>; Thu, 31 Oct 2002 17:51:50 -0600 (CST)
Received: from cse.unl.edu ([129.93.33.1])
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002103117514924510
for <GRASSLIST@baylor.edu>; Thu, 31 Oct 2002 17:51:49 -0600
Received: from crow.unl.edu (nobody@crow.unl.edu [129.93.32.85])
  by cse.unl.edu (8.9.1/8.9.1) with ESMTP id RAA40986;
  Thu, 31 Oct 2002 17:51:48 -0600 (CST)
Received: from localhost (xwu@localhost)
  by crow.unl.edu (8.11.6+Sun/8.9.1) with ESMTP id g9VNpmP00902;
Date: Thu, 31 Oct 2002 17:51:48 -0600 (CST)
To: cbsled@ncia.net
cc: GRASSLIST@baylor.edu
Subject: [GRASSLIST:4867] Re: copying regions between systems
In-Reply-To: <20021031224621.0DB5E38376@bobcat.ncia.net>
Message-ID: <Pine.GSO.4.05.10210311748370.798-100000@crow.unl.edu>
MIME-Version: 1.0
Content-Type: TEXT/PLAIN; charset=US-ASCII
X-OriginalArrivalTime: 31 Oct 2002 23:51:50.0008 (UTC) FILETIME=[7AE9A780:01C28138]
Status: O
Content-Length: 623
Lines: 25
What I usually do is following:
1. create a new mapset in new location.
2. copy the subdirectories from the original mapset, such as cats,
   dig and so on.
3. run some support command, such as r.support, v.support and so on.
Hope this may be help.
Xueming
TIA
From - Mon Nov 4 08:07:18 2002
X-UIDL: 3d0f087300007258
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id BAA13199;
  Fri, 1 Nov 2002 01:18:00 +0100 (MET)
Received: from waylon.baylor.edu ([129.62.3.228]) by fw; Fri, 01 Nov 2002 01:17:59 +0100 (MET)
   Thu, 31 Oct 2002 18:17:58 -0600
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id SAA1102598;
  Thu, 31 Oct 2002 18:17:56 -0600 (CST)
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id SAA1102211
  for <GRASSLIST@listproc.baylor.edu>; Thu, 31 Oct 2002 18:17:53 -0600 (CST)
Received: from mta4-svc.business.ntl.com ([62.253.164.44])
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002103118175314908
for <GRASSLIST@baylor.edu>; Thu, 31 Oct 2002 18:17:53 -0600
Received: from cerise.nosuchdomain.co.uk ([62.252.4.28])
          by mta4-svc.business.ntl.com
          (InterMail vM.4.01.03.27 201-229-121-127-20010626) with ESMTP
          id <20021101001751.JSPQ21311.mta4-svc.business.ntl.com@cerise.nosuchdomain.co.uk>;
          Fri, 1 Nov 2002 00:17:51 +0000
Received: (from glynn@localhost)
  by gA102sg01344 (8.11.6/8.11.6) id gA102sg01344;
  Fri, 1 Nov 2002 00:02:54 GMT
MIME-Version: 1.0
Content-Transfer-Encoding: 7bit
Message-ID: <15809.50350.222491.353442@cerise.nosuchdomain.co.uk>
Date: Fri, 1 Nov 2002 00:02:54 +0000
To: cbsled@ncia.net
Subject: [GRASSLIST:4868] Re: copying regions between systems
References: <20021031224621.0DB5E38376@bobcat.ncia.net>
X-Mailer: VM 6.94 under 21.4 (patch 10) "Military Intelligence (RC3)" XEmacs Lucid
X-OriginalArrivalTime: 01 Nov 2002 00:17:53.0720 (UTC) FILETIME=[1EF52B80:01C2813C]
Status: O
Content-Length: 700
Lines: 21
another machine?
Are you referring to a "location" directory? If so, then you can
safely transfer the directory to another machine of the same
architecture.
For machines of differing architectures, the situation isn't so clear
cut. Any ASCII files (WIND, cell_hd, colr, sites etc) are portable, as
are the cell files. I don't know about vector files. Some modules may
create additional files using their own private format, and some of
these aren't portable (e.g. the raw FFT output from i.fft).
X-UIDL: 3d0f087300007259
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id BAA13216;
  Fri, 1 Nov 2002 01:18:20 +0100 (MET)
Received: from waylon.baylor.edu ([129.62.3.228]) by fw; Fri, 01 Nov 2002 01:18:20 +0100 (MET)
   Thu, 31 Oct 2002 18:18:19 -0600
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id SAA1102714;
  Thu, 31 Oct 2002 18:18:18 -0600 (CST)
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id SAA1102455
  for <GRASSLIST@listproc.baylor.edu>; Thu, 31 Oct 2002 18:18:01 -0600 (CST)
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002103118180127445
for <GRASSLIST@baylor.edu>; Thu, 31 Oct 2002 18:18:01 -0600
          id <20021101001800.JSRU21311.mta4-svc.business.ntl.com@cerise.nosuchdomain.co.uk>;
          Fri, 1 Nov 2002 00:18:00 +0000
  by gA10Djh01346 (8.11.6/8.11.6) id gA10Djh01346;
  Fri, 1 Nov 2002 00:13:45 GMT
MIME-Version: 1.0
Message-ID: <15809.51001.251596.404688@cerise.nosuchdomain.co.uk>
Date: Fri, 1 Nov 2002 00:13:45 +0000
To: Xiangzhou Wang <xiangw@yahoo.com>
Cc: GRASSLIST@baylor.edu
Subject: [GRASSLIST:4869] Re: GRASS multiple language support
In-Reply-To: <20021031222213.94192.qmail@web10102.mail.yahoo.com>
References: <20021031222213.94192.qmail@web10102.mail.yahoo.com>
X-OriginalArrivalTime: 01 Nov 2002 00:18:01.0798 (UTC) FILETIME=[23C5C660:01C2813C]
Status: O
Content-Length: 890
Lines: 30
Chinese/Japanese.
In general, no.
Primitive internationalisation support has been added in 5.0.0;
however, currently only the PostgreSQL modules have been
internationalised, and the only localised message catalogues are for
Russian.
The latest CVS version also includes internationalisation of the core
libgis library, the session startup, and tcltkgrass. Again, the only
existing message catalogues are for Russian.
However, even if you were to construct Chinese/Japanese message
catalogues for those parts which have been internationalised, the
curses-based interfaces won't handle double-width characters
correctly.
OTOH, d.text.freetype does support displaying CJK text.
From - Mon Nov 4 08:07:30 2002
X-UIDL: 3d0f08730000726d
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id KAA17875;
  Fri, 1 Nov 2002 10:59:51 +0100 (MET)
Received: from waylon.baylor.edu ([129.62.3.228]) by fw; Fri, 01 Nov 2002 10:59:50 +0100 (MET)
   Fri, 1 Nov 2002 03:59:48 -0600
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id DAA1247490;
  Fri, 1 Nov 2002 03:59:28 -0600 (CST)
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id DAA1247661
  for <GRASSLIST@listproc.baylor.edu>; Fri, 1 Nov 2002 03:59:24 -0600 (CST)
   Fri, 1 Nov 2002 03:59:23 -0600
Received: from email01.aon.at ([195.3.96.97])
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002110103592320054
for <GRASSLIST@baylor.edu>; Fri, 01 Nov 2002 03:59:23 -0600
Received: (qmail 264836 invoked from network); 1 Nov 2002 09:59:22 -0000
Received: from m131p021.adsl.highway.telekom.at (HELO t1) ([62.47.184.85]) (envelope-sender <thomas.anzboeck@sbg.ac.at>)
          by qmail1rs.highway.telekom.at (qmail-ldap-1.03) with SMTP
          for <GRASSLIST@baylor.edu>; 1 Nov 2002 09:59:22 -0000
From: =?iso-8859-1?Q?Thomas_Anzb=F6ck?= <thomas.anzboeck@sbg.ac.at>
To: "GRASSLIST" <GRASSLIST@baylor.edu>
Subject: [GRASSLIST:4870] nviz starts but then breaks down
Date: Fri, 1 Nov 2002 11:01:59 +0100
Message-ID: <AOEOKEDANJAFCBMPEJDBIEFACDAA.thomas.anzboeck@sbg.ac.at>
MIME-Version: 1.0
  charset="iso-8859-1"
X-Priority: 3 (Normal)
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook IMO, Build 9.0.2416 (9.0.2910.0)
Importance: Normal
X-MimeOLE: Produced By Microsoft MimeOLE V5.00.2919.6700
X-OriginalArrivalTime: 01 Nov 2002 09:59:23.0865 (UTC) FILETIME=[5B1ACC90:01C2818D]
Status: O
Content-Length: 868
Lines: 34
After starting, nviz quits with error:
Loading Data
Update elev null mask
Loading Data
translating colors
Adding panels from /usr/local/Programm/grass5/etc/nviz2.2/scripts
Nv_(panels)
toplevel made
child killed: segmentation violation
    while executing
"exec /usr/local/Programm/grass5/etc/nviz2.2/NVWISH2.2 -f
/usr/local/Programm/grass5/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ
&@stdout"
    ("eval" body line 1)
    invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
$env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdout"
    invoked from within
"if {$argv == ""} {
#no arguments
$env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdo..."
    (file "/usr/local/Programm/grass5/bin/nviz" line 16)
GRASS:~ >
what can I do?
thanks in advance
thomas
From - Mon Nov 4 08:07:32 2002
X-UIDL: 3d0f087300007278
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id OAA01863;
  Fri, 1 Nov 2002 14:35:51 +0100 (MET)
Received: from waylon.baylor.edu ([129.62.3.228]) by fw; Fri, 01 Nov 2002 14:35:50 +0100 (MET)
   Fri, 1 Nov 2002 07:35:35 -0600
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id HAA1374325;
  Fri, 1 Nov 2002 07:35:18 -0600 (CST)
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id HAA1374060
  for <GRASSLIST@listproc.baylor.edu>; Fri, 1 Nov 2002 07:35:13 -0600 (CST)
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002110107351311709
for <GRASSLIST@baylor.edu>; Fri, 01 Nov 2002 07:35:13 -0600
Received: from Omnit (ncia-lfp-57.ncia.net [206.243.130.57])
  id 97683384DF; Fri, 1 Nov 2002 08:32:33 -0500 (EST)
Date: Fri, 01 Nov 2002 08:26:42 -0500
To: Glynn Clements <glynn.clements@virgin.net>, <GRASSLIST@baylor.edu>
In-Reply-To: <15809.50350.222491.353442@cerise.nosuchdomain.co.uk>
Subject: [GRASSLIST:4871] Re: copying regions between systems
Message-Id: <20021101133233.97683384DF@bobcat.ncia.net>
X-OriginalArrivalTime: 01 Nov 2002 13:35:13.0223 (UTC) FILETIME=[81860570:01C281AB]
Status: O
Content-Length: 544
Lines: 16
Yes. The ones that are created in the database dir when you make a new location in GRASS.
For machines of differing architectures, the situation isn't so clear cut.
One is a Redhat desktop PC, the other is an Apple Powerbook running
Yellow Dog Linux. We shall see...
From - Mon Nov 4 08:07:35 2002
X-UIDL: 3d0f087300007285
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id SAA12494;
  Fri, 1 Nov 2002 18:09:35 +0100 (MET)
Received: from waylon.baylor.edu ([129.62.3.228]) by fw; Fri, 01 Nov 2002 18:09:33 +0100 (MET)
   Fri, 1 Nov 2002 11:09:28 -0600
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id LAA1431617;
  Fri, 1 Nov 2002 11:09:01 -0600 (CST)
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id LAA1431813
  for <GRASSLIST@listproc.baylor.edu>; Fri, 1 Nov 2002 11:08:58 -0600 (CST)
   Fri, 1 Nov 2002 11:08:45 -0600
Received: from VAN-E2K1.safe.internal ([24.76.241.186])
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002110111084420050
for <GRASSLIST@baylor.edu>; Fri, 01 Nov 2002 11:08:45 -0600
content-class: urn:content-classes:message
MIME-Version: 1.0
X-MIMEOLE: Produced By Microsoft Exchange V6.0.5762.3
Subject: [GRASSLIST:4872] Grass Installation
Date: Fri, 1 Nov 2002 09:08:39 -0800
Message-ID: <CB8D74468A40754791B9F85EAE581CE581A09B@VAN-E2K1.safe.internal>
Thread-Topic: Grass Installation
Thread-Index: AcKByVLBtDKNJFrXQJKvxzU3khJnKQ==
X-OriginalArrivalTime: 01 Nov 2002 17:08:45.0280 (UTC) FILETIME=[561AC600:01C281C9]
X-MIME-Autoconverted: from quoted-printable to 8bit by ccis01.baylor.edu id LAA1431851
Status: O
Content-Length: 251
Lines: 12
I tried to install grass 5 snapshot 08/2002 and got the following message from ./configure:
error: failed to find postgresql includes.
I then installed postgresql and tried again. Didn't help.
Any idea what I can do to fix this?
-Daniel
X-UIDL: 3d0f087300007288
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id SAA17068;
  Fri, 1 Nov 2002 18:38:16 +0100 (MET)
Received: from waylon.baylor.edu ([129.62.3.228]) by fw; Fri, 01 Nov 2002 18:38:15 +0100 (MET)
   Fri, 1 Nov 2002 11:38:14 -0600
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id LAA1439271;
  Fri, 1 Nov 2002 11:38:04 -0600 (CST)
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id LAA1438861
  for <GRASSLIST@listproc.baylor.edu>; Fri, 1 Nov 2002 11:38:01 -0600 (CST)
   Fri, 1 Nov 2002 11:37:37 -0600
   Fri, 1 Nov 2002 11:37:38 -0600
Received: from mail.tiscali.it ([195.130.225.149])
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002110111373722845
for <GRASSLIST@baylor.edu>; Fri, 01 Nov 2002 11:37:37 -0600
Received: from ambn8o4g8mxtrn (62.11.158.75) by mail.tiscali.it (6.5.026)
        id 3DAE56A90094998B for GRASSLIST@baylor.edu; Fri, 1 Nov 2002 18:37:33 +0100
Message-ID: <000e01c281cd$e969f7b0$4b9e0b3e@ambn8o4g8mxtrn>
Subject: [GRASSLIST:4873] DTM from a dxf-3D file
Date: Fri, 1 Nov 2002 18:41:29 +0100
MIME-Version: 1.0
Content-Type: multipart/alternative;
  boundary="----=_NextPart_000_000B_01C281D6.4A98AF60"
X-Priority: 3
X-Mailer: Microsoft Outlook Express 6.00.2600.0000
X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2600.0000
X-OriginalArrivalTime: 01 Nov 2002 17:37:38.0054 (UTC) FILETIME=[5EEB1A60:01C281CD]
Status: O
Content-Length: 2491
Lines: 69
This is a multi-part message in MIME format.
------=_NextPart_000_000B_01C281D6.4A98AF60
Content-Transfer-Encoding: quoted-printable
Thanks to all for the answers to my previous question (nviz libpq.so =
error):
Now nviz run correctly.
I need to create a DTM starting from a dxf-3D file with contour lines.
I try to import with command v.in.dxf and v.support to rebuild topology =
and v.to rast but the=20
the problem is that when i convert the vector contour map (.DFX) to =
raster i get a raster=20
file containing patches or points of different colors rather then the =
actual contour lines
To run v.surf.rst program caused a sudden crash system. Is this method =
wrong?
Can anyone please tell me which are the correct steps to create the DTM =
raster map?
Thanks,=20
Andrea Mamusa
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2600.0" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV>
<DIV><FONT face=3DArial size=3D2>Hi,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks to all for the answers to my =
previous=20
question (nviz libpq.so error):</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Now nviz run correctly.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>I need to create a DTM starting from a =
dxf-3D file=20
with contour lines.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I try to import with command v.in.dxf =
and v.support=20
to rebuild topology and v.to rast but the </FONT></DIV>
<DIV>the problem is that when i convert&nbsp;the vector contour map =
(.DFX) to=20
raster i get a raster <BR>file containing patches or points&nbsp;of =
different=20
colors rather then the actual contour lines</DIV>
<DIV><FONT face=3DArial size=3D2>To run&nbsp;v.surf.rst program =
caused&nbsp;a sudden=20
crash system. Is this method wrong?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Can anyone please tell me&nbsp;which =
are the=20
correct steps to create the DTM raster map?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks, </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Andrea =
Mamusa</FONT></DIV></DIV></BODY></HTML>
------=_NextPart_000_000B_01C281D6.4A98AF60--
From - Mon Nov 4 08:07:42 2002
X-UIDL: 3d0f08730000729f
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id LAA23926;
  Sat, 2 Nov 2002 11:16:04 +0100 (MET)
Received: from waylon.baylor.edu ([129.62.3.228]) by fw; Sat, 02 Nov 2002 11:16:02 +0100 (MET)
   Sat, 2 Nov 2002 04:16:01 -0600
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id EAA1139951;
  Sat, 2 Nov 2002 04:15:39 -0600 (CST)
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id EAA1140084
  for <GRASSLIST@listproc.baylor.edu>; Sat, 2 Nov 2002 04:15:35 -0600 (CST)
   Sat, 2 Nov 2002 04:15:34 -0600
Received: from mta1-svc.business.ntl.com ([62.253.164.41])
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002110204153409723
for <GRASSLIST@baylor.edu>; Sat, 02 Nov 2002 04:15:34 -0600
Received: from cerise.nosuchdomain.co.uk ([62.252.4.35])
          by mta1-svc.business.ntl.com
          id <20021102101532.BZBP277.mta1-svc.business.ntl.com@cerise.nosuchdomain.co.uk>;
          Sat, 2 Nov 2002 10:15:32 +0000
  by gA239EW01130 (8.11.6/8.11.6) id gA239EW01130;
  Sat, 2 Nov 2002 03:09:14 GMT
MIME-Version: 1.0
Message-ID: <15811.16858.313840.93153@cerise.nosuchdomain.co.uk>
Date: Sat, 2 Nov 2002 03:09:14 +0000
To: "Dan Gelinas" <Daniel.Gelinas@safe.com>
Subject: [GRASSLIST:4874] Re: Grass Installation
In-Reply-To: <CB8D74468A40754791B9F85EAE581CE581A09B@VAN-E2K1.safe.internal>
References: <CB8D74468A40754791B9F85EAE581CE581A09B@VAN-E2K1.safe.internal>
X-OriginalArrivalTime: 02 Nov 2002 10:15:35.0122 (UTC) FILETIME=[C86E9B20:01C28258]
Status: O
Content-Length: 498
Lines: 20
  ./configure --with-postgres-includes=...
Unless the headers are in one of the compiler's default directories
(e.g. /usr/include), you have to tell configure where to find them.
From - Mon Nov 4 08:07:43 2002
X-UIDL: 3d0f0873000072a5
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id UAA20184;
  Sat, 2 Nov 2002 20:17:27 +0100 (MET)
Received: from waylon.baylor.edu ([129.62.3.228]) by fw; Sat, 02 Nov 2002 20:17:26 +0100 (MET)
   Sat, 2 Nov 2002 13:17:25 -0600
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id NAA1281509;
  Sat, 2 Nov 2002 13:17:06 -0600 (CST)
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id NAA1278710
  for <GRASSLIST@listproc.baylor.edu>; Sat, 2 Nov 2002 13:17:03 -0600 (CST)
   Sat, 2 Nov 2002 13:17:04 -0600
Received: from mail.maich.gr ([193.218.36.74])
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002110213170027640
for <GRASSLIST@baylor.edu>; Sat, 02 Nov 2002 13:17:01 -0600
Date: Sat, 2 Nov 2002 21:48:10 +0200
Message-Id: <200211022148.AA21365062@mail.maich.gr>
Mime-Version: 1.0
Reply-To: <gis@maich.gr>
X-Sender: <gis@mail.maich.gr>
Subject: [GRASSLIST:4875] v.in.dgn problem
X-Mailer: <IMail v6.05>
X-OriginalArrivalTime: 02 Nov 2002 19:17:03.0841 (UTC) FILETIME=[6D37B510:01C282A4]
Status: RO
Content-Length: 470
Lines: 7
            Hi everybody,
  I have grass5.0 on my machine and during the compilation I did not get any errors. Despite of this the v.in.dgn (v.out.dgn also) module was not compiled. Now I needed to use it and I run gmake5 -i to build it but it exit with error. The error message says that the file dgnlibp.h does not exist. It search for it in ../include.
  If someone knows how to fix this or can tell me from where I can get the header file please write me.
From - Mon Nov 4 08:07:45 2002
X-UIDL: 3d0f0873000072b3
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id OAA05214;
  Sun, 3 Nov 2002 14:10:20 +0100 (MET)
Received: from waylon.baylor.edu ([129.62.3.228]) by fw; Sun, 03 Nov 2002 14:10:18 +0100 (MET)
   Sun, 3 Nov 2002 07:10:17 -0600
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id HAA1478958;
  Sun, 3 Nov 2002 07:09:40 -0600 (CST)
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id HAA1498845
  for <GRASSLIST@listproc.baylor.edu>; Sun, 3 Nov 2002 07:09:37 -0600 (CST)
Received: from mehl.gfz-potsdam.de ([139.17.1.100])
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002110307093627200
for <GRASSLIST@baylor.edu>; Sun, 03 Nov 2002 07:09:36 -0600
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id OAA04782
  for <GRASSLIST@baylor.edu>; Sun, 3 Nov 2002 14:09:34 +0100 (MET)
Received: from webmail.gfz-potsdam.de ([139.17.3.21]) by fw; Sun, 03 Nov 2002 14:09:32 +0100 (MET)
X-WebMail-UserID: eicksch
Date: Sun, 3 Nov 2002 14:03:47 +0100
X-EXP32-SerialNo: 00003529
Subject: [GRASSLIST:4876] image classification question
Message-ID: <3D814545@webmail>
Mime-Version: 1.0
Content-Type: text/plain; charset="ISO-8859-1"
X-Mailer: WebMail (Hydra) SMTP v3.61
X-OriginalArrivalTime: 03 Nov 2002 13:09:37.0869 (UTC) FILETIME=[433517D0:01C2833A]
X-Sender: eicksch <eicksch@gfz-potsdam.de>
Status: O
Content-Length: 1430
Lines: 38
I have two sets of image/raster data of the same region acquired at
different times. I am able to perform unsupervised radiometric
classifications on each of them. Just for interest I would like to classify
each of the scenes using the signatures defined for the other image (group).
For instance, to classify scene2 with the signatures from scene1, I cd'ed to
        $LOCATION/group/group2/subgroup/subgroup2/sig
and made a
        ln -s $LOCATION/group/group1/subgroup/subgroup1/sig/sigfile1 .
Unfotunatly,
        i.maxlik group=scene2 subgroup=subscene2 sigfile=sigfile1
class=scene2.sig1
results in
        Can't read signature file sigfile1
I fear, that it isn't related to the existance of the file but all the
contents (the number of pixels per class, the variance matrices etc.).
What did I make wrong and how can I get my results?
In other words: How can I generate a (valid) signature file by hand?
All this applies to GRASS 4.2.1.
Thanks in advance for any help,
Stephan
Stephan Eickschen Tel. : +49 (0)8153 28-1351
GeoForschungsZentrum Potsdam (GFZ) Fax. : +49 (0)8153 28-1207
Division 1, Section 1.2
c/o email: eicksch@gfz-potsdam.de
DLR Oberpfaffenhofen
82234 Wessling
Germany
From - Mon Nov 4 11:58:31 2002
X-UIDL: 3d0f0873000072e3
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id LAA12097;
  Mon, 4 Nov 2002 11:48:24 +0100 (MET)
Received: from waylon.baylor.edu ([129.62.3.228]) by fw; Mon, 04 Nov 2002 11:48:22 +0100 (MET)
   Mon, 4 Nov 2002 04:48:14 -0600
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id EAA1267379;
  Mon, 4 Nov 2002 04:47:47 -0600 (CST)
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id EAA1267038
  for <GRASSLIST@listproc.baylor.edu>; Mon, 4 Nov 2002 04:47:43 -0600 (CST)
Received: from camelot.itc.it ([195.223.171.5])
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002110404473804133
for <GRASSLIST@baylor.edu>; Mon, 04 Nov 2002 04:47:40 -0600
Received: from orchestra.itc.it (orchestra [10.0.10.11])
  by camelot.itc.it (8.11.3/8.11.3) with ESMTP id gA4AlZX12768
  for <GRASSLIST@baylor.edu>; Mon, 4 Nov 2002 11:47:36 +0100 (MET)
Received: from thuille.itc.it. (thuille [10.40.0.110])
  by orchestra.itc.it (8.11.6/8.11.6) with ESMTP id gA4AlZt02910
  for <GRASSLIST@baylor.edu>; Mon, 4 Nov 2002 11:47:35 +0100
Received: (from neteler@localhost)
  by thuille.itc.it. (8.11.6/8.11.2) id gA4AlZn26202
  for GRASSLIST@baylor.edu; Mon, 4 Nov 2002 11:47:35 +0100
Date: Mon, 4 Nov 2002 11:47:35 +0100
Subject: [GRASSLIST:4877] Re: v.in.dgn problem
Message-ID: <20021104114735.K16430@itc.it>
Mail-Followup-To: GRASSLIST@baylor.edu
References: <200211022148.AA21365062@mail.maich.gr>
Mime-Version: 1.0
Content-Disposition: inline
User-Agent: Mutt/1.2.5.1i
In-Reply-To: <200211022148.AA21365062@mail.maich.gr>; from gis@maich.gr on Sat, Nov 02, 2002 at 09:48:10PM +0200
X-OriginalArrivalTime: 04 Nov 2002 10:47:43.0223 (UTC) FILETIME=[9A7EF870:01C283EF]
Status: O
Content-Length: 793
Lines: 17
On Sat, Nov 02, 2002 at 09:48:10PM +0200, gis Lab wrote:
            Hi everybody,
The v.in.dgn was recently changed in CVS. Here is the latest code:
http://freegis.org/cgi-bin/viewcvs.cgi/grass/src/mapdev/v.in.dgn/v.in.dgn.tar.gz?tarball=1
The README describes briefly that the dgn header files must be used from
GDAL/OGR.
From - Mon Nov 4 12:08:31 2002
X-UIDL: 3d0f0873000072e5
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id MAA16424;
  Mon, 4 Nov 2002 12:07:01 +0100 (MET)
Received: from waylon.baylor.edu ([129.62.3.228]) by fw; Mon, 04 Nov 2002 12:07:01 +0100 (MET)
   Mon, 4 Nov 2002 05:06:59 -0600
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id FAA1270775;
  Mon, 4 Nov 2002 05:06:47 -0600 (CST)
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id FAA1270106
  for <GRASSLIST@listproc.baylor.edu>; Mon, 4 Nov 2002 05:06:43 -0600 (CST)
Received: from salome.datron.cz ([194.212.10.137])
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002110405064111405
for <GRASSLIST@baylor.edu>; Mon, 04 Nov 2002 05:06:42 -0600
Received: from salome.datron.cz (localhost [127.0.0.1])
  by salome.datron.cz (8.12.3/8.12.3) with ESMTP id gA4B6fHg002356
  for <GRASSLIST@baylor.edu>; Mon, 4 Nov 2002 12:06:41 +0100
Received: (from znouza@localhost)
  by salome.datron.cz (8.12.3/8.12.3/Submit) id gA4B6ece002355
  for GRASSLIST@baylor.edu; Mon, 4 Nov 2002 12:06:40 +0100
X-Authentication-Warning: salome.datron.cz: znouza set sender to tm@salome.datron.cz using -f
Date: Mon, 4 Nov 2002 12:06:40 +0100
Subject: [GRASSLIST:4878] v.in.dgn
Message-ID: <20021104120640.B2127@salome.datron.cz>
Mime-Version: 1.0
User-Agent: Mutt/1.3.23i
X-Operating-System: Linux 2.2.19 on i686
X-PGP-Key: http://www.meinlschmidt.org/public.asc
X-RAVMilter-Version: 8.3.1(snapshot 20020108) (salome)
X-OriginalArrivalTime: 04 Nov 2002 11:06:43.0416 (UTC) FILETIME=[421A9D80:01C283F2]
Status: O
Content-Length: 750
Lines: 20
as I've seen, v.in.dgn exists! :slight_smile: it's marvellous but I have one question:
it's applicable to dgn data with contours - created as lines/polylines instead
of polygons?
Thanl you
tom
Tomas Meinlschmidt, SBN3, MCT, MCP, MCP+I, MCSE, NetApp Filer & NetCache
Datron s.r.o., Vachkova 3008, 470 01 Ceska Lipa, 487 834 421, f: 487 834 425
gPG fp: D6F7 B1EE 33DA 2073 4EB1 AC60 0A9F FE09 98ED FB06 / $ID: 98EDFB06
GCS d-(?) s: a- C++ ULHISC*++++$ P+++>++++ L+++$>++++ E--- W+++$ N++(+) !o
    !K w(---) !O !M V PS+ PE Y+ PGP++ t+@ !5 X? R tv b+ !DI D+ G e>+++
    h---- r+++ z+++@
From - Mon Nov 4 12:28:30 2002
X-UIDL: 3d0f0873000072e6
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id MAA18835;
  Mon, 4 Nov 2002 12:18:47 +0100 (MET)
Received: from waylon.baylor.edu ([129.62.3.228]) by fw; Mon, 04 Nov 2002 12:18:46 +0100 (MET)
   Mon, 4 Nov 2002 05:18:44 -0600
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id FAA1272795;
  Mon, 4 Nov 2002 05:18:38 -0600 (CST)
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id FAA1272807
  for <GRASSLIST@listproc.baylor.edu>; Mon, 4 Nov 2002 05:18:35 -0600 (CST)
Received: from email03.aon.at ([195.3.96.93])
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002110405183402190
for <GRASSLIST@baylor.edu>; Mon, 04 Nov 2002 05:18:34 -0600
Received: (qmail 451324 invoked from network); 4 Nov 2002 11:18:07 -0000
Received: from m129p029.adsl.highway.telekom.at (HELO t1) ([62.47.184.29]) (envelope-sender <thomas.anzboeck@sbg.ac.at>)
          by qmail3rs.highway.telekom.at (qmail-ldap-1.03) with SMTP
          for <GRASSLIST@baylor.edu>; 4 Nov 2002 11:18:07 -0000
Subject: [GRASSLIST:4879] WinGrass: NVIZ still fails
Date: Mon, 4 Nov 2002 12:20:49 +0100
Message-ID: <AOEOKEDANJAFCBMPEJDBOEFJCDAA.thomas.anzboeck@sbg.ac.at>
MIME-Version: 1.0
X-MIMEOLE: Produced By Microsoft MimeOLE V5.00.2919.6700
Importance: Normal
X-OriginalArrivalTime: 04 Nov 2002 11:18:35.0563 (UTC) FILETIME=[EA939FB0:01C283F3]
Status: O
Content-Length: 211
Lines: 9
I am still not able to run NVIZ neither on SUSE Linux nor with the
Wingrass-Version.
The error message on WinGrass is
cygtcl.dll not found ...
tcltkgrass seems to run without problems
thanks in advance
thomas
From - Mon Nov 4 13:28:35 2002
X-UIDL: 3d0f0873000072e9
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id NAA04223;
  Mon, 4 Nov 2002 13:21:08 +0100 (MET)
Received: from waylon.baylor.edu ([129.62.3.228]) by fw; Mon, 04 Nov 2002 13:21:06 +0100 (MET)
   Mon, 4 Nov 2002 06:21:02 -0600
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id GAA1328053;
  Mon, 4 Nov 2002 06:20:55 -0600 (CST)
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id GAA1328381
  for <GRASSLIST@listproc.baylor.edu>; Mon, 4 Nov 2002 06:20:52 -0600 (CST)
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002110406204828712
for <GRASSLIST@baylor.edu>; Mon, 04 Nov 2002 06:20:50 -0600
  by camelot.itc.it (8.11.3/8.11.3) with ESMTP id gA4CKYX27481;
  Mon, 4 Nov 2002 13:20:34 +0100 (MET)
Received: from janacek.itc.it. (janacek [10.40.0.140])
  by orchestra.itc.it (8.11.6/8.11.6) with ESMTP id gA4CKYt10846;
Received: from localhost (localhost [[UNIX: localhost]])
  by janacek.itc.it. (8.11.6/8.11.2) id gA4CKYF01150;
To: "Tom Z. Meinlschmidt" <tm@salome.datron.cz>
Subject: [GRASSLIST:4880] Re: v.in.dgn
Date: Mon, 4 Nov 2002 13:20:33 +0100
X-Mailer: KMail [version 1.2]
References: <20021104120640.B2127@salome.datron.cz>
In-Reply-To: <20021104120640.B2127@salome.datron.cz>
MIME-Version: 1.0
Message-Id: <02110413203300.01109@janacek>
X-OriginalArrivalTime: 04 Nov 2002 12:20:52.0245 (UTC) FILETIME=[9DD00C50:01C283FC]
Status: O
Content-Length: 422
Lines: 13
On Monday 04 November 2002 12:06 pm, you wrote:
instead of polygons?
v.in.dgn currently supports: LINE, LINE_STRING, SHAPE, TEXT
and doesn't support: ARC, CURVE, TEXT_NODE, CELL_HEADER,
COMPLEX_CHAIN_HEADER, COMPLEX_SHAPE_HEADER, ELLIPSE, BSPLINE
Radim
From - Tue Nov 5 08:15:10 2002
X-UIDL: 3d0f0873000072f5
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id RAA06502;
  Mon, 4 Nov 2002 17:38:31 +0100 (MET)
Received: from waylon.baylor.edu ([129.62.3.228]) by fw; Mon, 04 Nov 2002 17:38:29 +0100 (MET)
   Mon, 4 Nov 2002 10:38:25 -0600
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id KAA1399766;
  Mon, 4 Nov 2002 10:38:14 -0600 (CST)
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id KAA1399592
  for <GRASSLIST@listproc.baylor.edu>; Mon, 4 Nov 2002 10:38:09 -0600 (CST)
Received: from mailgw3a.lmco.com ([192.35.35.7])
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002110410380701299
for <grasslist@baylor.edu>; Mon, 04 Nov 2002 10:38:08 -0600
Received: from emss04g01.ems.lmco.com ([166.17.13.122])
  by mailgw3a.lmco.com (8.11.6/8.11.6) with ESMTP id gA4Gc6o17858
  for <grasslist@baylor.edu>; Mon, 4 Nov 2002 11:38:06 -0500 (EST)
Received: from CONVERSION-DAEMON.lmco.com by lmco.com (PMDF V6.1-1 #40649)
id <0H5200H015FIQP@lmco.com> for grasslist@baylor.edu; Mon, 04 Nov 2002 11:38:03 -0500 (EST)
Received: from EMSS04I00.us.lmco.com ([166.17.13.135]) by lmco.com (PMDF V6.1-1 #40649)
with ESMTP id <0H5200K8I86TK4@lmco.com> for grasslist@baylor.edu; Mon, 04 Nov 2002 11:23:17 -0500 (EST)
Received: by EMSS04I00.us.lmco.com with Internet Mail Service (5.5.2653.19) id <WA7K1AQ0>; Mon, 04 Nov 2002 11:23:19 -0500
Content-return: allowed
Date: Mon, 04 Nov 2002 11:22:53 -0500
From: "Allard, Yannick (EXP)" <yannick.allard@lmco.com>
Subject: [GRASSLIST:4882] mapset creation in java
To: "'grasslist@baylor.edu'" <grasslist@baylor.edu>
Message-id: <0DC5E833533ED4119B1500508BDF57DCB52137@emss52m02.lmcda.lmco.com>
MIME-version: 1.0
X-Mailer: Internet Mail Service (5.5.2653.19)
Content-transfer-encoding: 7BIT
X-OriginalArrivalTime: 04 Nov 2002 16:38:09.0083 (UTC) FILETIME=[8EE298B0:01C28420]
Status: O
Content-Length: 258
Lines: 16
Hi everyone
does anyone knows how to create a mapset with the Java API...
thanks in advance
yannick
Yannick Allard
Ph.D student, Universite de Sherbrooke
R&D senior associate member
Lockheed Martin Canada
6111 Royalmount, Montreal
(514) 340-8310 #7776
From - Tue Nov 5 08:15:13 2002
X-UIDL: 3d0f0873000072f6
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id RAA06815;
  Mon, 4 Nov 2002 17:41:33 +0100 (MET)
Received: from waylon.baylor.edu ([129.62.3.228]) by fw; Mon, 04 Nov 2002 17:41:31 +0100 (MET)
   Mon, 4 Nov 2002 10:41:28 -0600
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id KAA1400432;
  Mon, 4 Nov 2002 10:41:27 -0600 (CST)
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id KAA1399428
  for <GRASSLIST@listproc.baylor.edu>; Mon, 4 Nov 2002 10:41:22 -0600 (CST)
Received: from stimpy.hamanndonald.com ([198.88.146.57])
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002110410412122639
for <GRASSLIST@baylor.edu>; Mon, 04 Nov 2002 10:41:22 -0600
Received: from godzilla (godzilla [192.168.0.3])
  by stimpy.hamanndonald.com (8.11.6/8.11.6) with SMTP id gA4GfKa07558
  for <GRASSLIST@baylor.edu>; Mon, 4 Nov 2002 08:41:20 -0800 (PST)
  (envelope-from jeff_hamann@hamanndonald.com)
Message-ID: <004a01c28420$eb68f7a0$0300a8c0@godzilla>
From: "Jeff D. Hamann" <jeff_hamann@hamanndonald.com>
Subject: [GRASSLIST:4883] best tutorial for cygwin?
Date: Mon, 4 Nov 2002 08:40:43 -0800
MIME-Version: 1.0
X-Priority: 3
X-MIMEOLE: Produced By Microsoft MimeOLE V6.00.2600.0000
X-OriginalArrivalTime: 04 Nov 2002 16:41:22.0777 (UTC) FILETIME=[0255F490:01C28421]
Status: O
Content-Length: 399
Lines: 15
I need to code up some models that will output grass raster files and I need
a very good tutorial that can get me generating grass raster files in a
hurry. What's the best tutorial out there for cygwin users?
Jeff.
Jeff D. Hamann
Hamann, Donald & Associates, Inc.
PO Box 1421
Corvallis, Oregon USA 97339-1421
Bus. 541-753-7333
Cell. 541-740-5988
www.hamanndonald.com
From - Tue Nov 5 08:15:18 2002
X-UIDL: 3d0f0873000072fa
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id SAA15451;
  Mon, 4 Nov 2002 18:29:45 +0100 (MET)
Received: from waylon.baylor.edu ([129.62.3.228]) by fw; Mon, 04 Nov 2002 18:29:43 +0100 (MET)
   Mon, 4 Nov 2002 11:29:40 -0600
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id LAA1409584;
  Mon, 4 Nov 2002 11:29:33 -0600 (CST)
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id LAA1409607
  for <GRASSLIST@listproc.baylor.edu>; Mon, 4 Nov 2002 11:29:28 -0600 (CST)
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002110411292721756
for <GRASSLIST@baylor.edu>; Mon, 04 Nov 2002 11:29:28 -0600
MIME-Version: 1.0
Subject: [GRASSLIST:4884] RE: Grass Installation
X-MimeOLE: Produced By Microsoft Exchange V6.0.5762.3
Date: Mon, 4 Nov 2002 09:29:27 -0800
Message-ID: <CB8D74468A40754791B9F85EAE581CE5111B75@VAN-E2K1.safe.internal>
Thread-Topic: [GRASSLIST:4872] Grass Installation
Thread-Index: AcKCWXe5Z/x7dFfQRAOLLSfXercvOwBzSiHg
X-OriginalArrivalTime: 04 Nov 2002 17:29:28.0760 (UTC) FILETIME=[BA840380:01C28427]
X-MIME-Autoconverted: from quoted-printable to 8bit by ccis01.baylor.edu id LAA1409523
Status: O
Content-Length: 1162
Lines: 44
Thanks.
So I assume the configure script doesn't know where to look for these include files? Unfortunately, neither do I :frowning:
Any idea where to look for these files AND, more importantly, what they are named?
I will check in the /usr/include.
Thanks again!
-----Original Message-----
From: Glynn Clements [mailto:glynn.clements@virgin.net]
Sent: Friday, November 01, 2002 7:09 PM
To: Dan Gelinas
Subject: Re: [GRASSLIST:4872] Grass Installation
X-UIDL: 3d0f0873000072fc
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id SAA18381;
  Mon, 4 Nov 2002 18:44:09 +0100 (MET)
Received: from waylon.baylor.edu ([129.62.3.228]) by fw; Mon, 04 Nov 2002 18:44:07 +0100 (MET)
   Mon, 4 Nov 2002 11:44:01 -0600
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id LAA1413673;
  Mon, 4 Nov 2002 11:43:54 -0600 (CST)
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id LAA1412961
  for <GRASSLIST@listproc.baylor.edu>; Mon, 4 Nov 2002 11:43:52 -0600 (CST)
Received: from carme.wyom.net ([63.173.212.8])
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002110411434917167
for <GRASSLIST@baylor.edu>; Mon, 04 Nov 2002 11:43:51 -0600
Received: from due.GreenwoodMap.com (wireless-212-235.wyom.net [63.173.212.235])
  by carme.wyom.net (Postfix) with ESMTP
  id 1BAD05C7D5; Mon, 4 Nov 2002 10:42:30 -0700 (MST)
Message-Id: <5.1.1.6.0.20021104103845.00a7c450@mail.GreenwoodMap.com>
X-Sender: greenwoodmap02@mail.GreenwoodMap.com
X-Mailer: QUALCOMM Windows Eudora Version 5.1.1
Date: Mon, 04 Nov 2002 10:44:06 -0700
Subject: [GRASSLIST:4885] RE: Grass Installation
In-Reply-To: <CB8D74468A40754791B9F85EAE581CE5111B75@VAN-E2K1.safe.inter
nal>
Mime-Version: 1.0
Content-Type: multipart/mixed; x-avg-checked=avg-ok-79EB1D51; boundary="=======5CEA514A======="
X-OriginalArrivalTime: 04 Nov 2002 17:43:52.0319 (UTC) FILETIME=[BD3CA8F0:01C28429]
Status: O
Content-Length: 2054
Lines: 74
--=======5CEA514A=======
Content-Type: text/plain; x-avg-checked=avg-ok-79EB1D51; charset=us-ascii; format=flowed
On my system, the following did the trick:
--with-postgres-includes='/usr/local/pgsql/include
/usr/local/pgsql/include/server'
I compiled PostgreSQL myself and used fairly standard locations. If you
installed PostgreSQL from your Linux distribution, the needed include files
may be elsewhere, but they are easy to find. Just examine the ./configure
output and note what file(s) it is not finding. Then do a 'locate' for that
file and include whatever directory(s) the file is in.
Rich
Thanks.
are named?
Thanks again!
To: Dan Gelinas
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
Rich@GreenwoodMap.com
(307) 733-0203
http://www.GreenwoodMap.com
--=======5CEA514A=======--
From - Tue Nov 5 08:15:19 2002
X-UIDL: 3d0f0873000072ff
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id TAA25493;
  Mon, 4 Nov 2002 19:13:43 +0100 (MET)
Received: from waylon.baylor.edu ([129.62.3.228]) by fw; Mon, 04 Nov 2002 19:13:41 +0100 (MET)
   Mon, 4 Nov 2002 12:13:39 -0600
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id MAA1419665;
  Mon, 4 Nov 2002 12:13:33 -0600 (CST)
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id MAA1419789
  for <GRASSLIST@listproc.baylor.edu>; Mon, 4 Nov 2002 12:13:32 -0600 (CST)
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002110412133105517
for <GRASSLIST@baylor.edu>; Mon, 04 Nov 2002 12:13:32 -0600
Received: from cerise.nosuchdomain.co.uk ([62.252.68.190])
          id <20021104181327.MDZG21311.mta4-svc.business.ntl.com@cerise.nosuchdomain.co.uk>;
          Mon, 4 Nov 2002 18:13:27 +0000
  by gA4I9Su01028 (8.11.6/8.11.6) id gA4I9Su01028;
  Mon, 4 Nov 2002 18:09:28 GMT
MIME-Version: 1.0
Message-ID: <15814.47064.501391.31568@cerise.nosuchdomain.co.uk>
Date: Mon, 4 Nov 2002 18:09:28 +0000
Subject: [GRASSLIST:4886] RE: Grass Installation
In-Reply-To: <CB8D74468A40754791B9F85EAE581CE5111B75@VAN-E2K1.safe.internal>
References: <CB8D74468A40754791B9F85EAE581CE5111B75@VAN-E2K1.safe.internal>
X-Mailer: VM 6.94 under 21.4 (patch 10) "Military Intelligence" XEmacs Lucid
X-OriginalArrivalTime: 04 Nov 2002 18:13:32.0438 (UTC) FILETIME=[E2454360:01C2842D]
Status: O
Content-Length: 1142
Lines: 37
Thanks.
they are named?
The files for which "configure" checks are:
a) libpq-fe.h, and
b) either postgres.h or postgres_fe.h
If you are using a package from your OS vendor, then the files will
probably be in a subdirectory of /usr/include. E.g. RedHat 6.2 puts
them in /usr/include/pgsql.
You will need to have installed the appropriate "development" package,
e.g. "postgresql-devel" for RedHat 6.2.
If libpq-fe.h and postgres.h/postgres_fe.h are in different
directories, you need to specify both directories, separated by a
space; you will need to enclude the argument in quotes, e.g.
./configure --with-postgres-includes='/usr/include/pgsql /usr/include/pgsql/internal'
From - Tue Nov 5 08:15:25 2002
X-UIDL: 3d0f08730000730e
  by mehl.gfz-potsdam.de (8.9.3/8.9.3) with SMTP id AAA18389;
  Tue, 5 Nov 2002 00:59:54 +0100 (MET)
Received: from waylon.baylor.edu ([129.62.3.228]) by fw; Tue, 05 Nov 2002 00:59:53 +0100 (MET)
   Mon, 4 Nov 2002 17:59:53 -0600
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id RAA1532604;
  Mon, 4 Nov 2002 17:59:52 -0600 (CST)
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id RAA1533739
  for <GRASSLIST@listproc.baylor.edu>; Mon, 4 Nov 2002 17:59:50 -0600 (CST)
Received: from mel-rto4.wanadoo.fr ([193.252.19.23])
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002110417594813906
for <GRASSLIST@baylor.edu>; Mon, 04 Nov 2002 17:59:49 -0600
Received: from mel-rta8.wanadoo.fr (193.252.19.79) by mel-rto4.wanadoo.fr (6.5.007)
        id 3DA24D32010A3FC1 for GRASSLIST@baylor.edu; Tue, 5 Nov 2002 00:59:48 +0100
Received: from hobbiton (193.250.141.124) by mel-rta8.wanadoo.fr (6.5.007)
        id 3DA24B4A01049524 for GRASSLIST@baylor.edu; Tue, 5 Nov 2002 00:59:48 +0100
Message-ID: <200211050259490558.000A4D6C@smtp.wanadoo.fr>
X-Mailer: Calypso Version 3.20.01.00 (4)
Date: Tue, 05 Nov 2002 02:59:49 +0300
From: "Guillaume Criloux" <guillaume.criloux@laposte.net>
Subject: [GRASSLIST:4888] Trouble with i.points3
Mime-Version: 1.0
X-OriginalArrivalTime: 04 Nov 2002 23:59:50.0260 (UTC) FILETIME=[42D14B40:01C2845E]
X-MIME-Autoconverted: from quoted-printable to 8bit by ccis01.baylor.edu id RAA1532439
Status: O
Content-Length: 967
Lines: 21
I'm a rather new GRASS user and I use it mainly for rectifying aerial images.
I live in Mayotte, Comoros Archipelago in the Mozambique Channel where we use a datum of the international 1924 ellipsoid and a UTM (38 south) projection system.
The local datum is called 'Combani 1950' and I wrote it in the datum.table file.In spite of this, i seem to be unable to use it correctly. When i try to use i.points3 over an XY projection system targeted to a location in our local system i get the following error message :
  cannot initialize pj
  cause: unknown elliptical parameter name
And back to the GRASS prompt it goes :frowning:
If the target location doesn't use any datum, there doesn't seem to be any problem. So, either there is a place that I don't know where i should write my datum informations, or i made a mistake writing them to datum.table.
Could anybody explain me this or review my datum file please.
Thanks in advance,
Guillaume Criloux
SIG Conseil
