Excellent; now I have categories on all my lines. I thought the way to "flatten" this so that all of the lines are of the same class would be to use v.reclass, but I keep getting the message, "WARNING: category support for vector file [lakes] in mapset [doug] missing". Do you know what I can do to fix that?
Doug Gorley | douggorley@shaw.ca
----- Original Message -----
Date: Sunday, December 1, 2002 7:20 pm
Subject: [GRASSLIST:5125] Re: Labeling imported layers
On Sun, Dec 01, 2002 at 07:09:48PM -0800, douggorley@shaw.ca wrote:
> I have access to Arc/Info with the source data. Is there a
better way
> to export the data so that I don't have to relabel everything?"export" as .e00 and use m.in.e00
"...the plural of anecdote is [not?] data." - attrib. to George
Stigler
