Moritz,
Did you try to commit my vector.tcl that I sent out yesterday? If so,
thanks. However, as you apparently noticed, Markus also committed Florian's
update of vector.tcl that allows for more icons. I will try to do a diff on
Monday (or probably Tuesday given my schedule tomorrow) and combine both
sets of changes. I also want to make the change to "sql color" that I
mentioned earlier today and maybe better describe what 'display constraints'
do if someone can enlighten me.
Michael
On 12/12/04 3:53 PM, "Moritz Lennert" <mlennert@club.worldonline.be> wrote:
On Sun, December 12, 2004 23:34, Hamish said:
I have a vector coverage of long, narrow polygons (riparian
buffers) that I would like to display only with shaded areas (i.e.
no boundaries). The boundaries essentially obscure the color ofmany> polygons because they are thin and small. Coloring them white
does> not seem to do the trick -- is there a way of either making thetransparent, or not drawing them at all?
d.vect fcolor=grey color=none
Any way of allowing a choice of 'none' in the GIS Manager ?
In d.m, after clicking on "Add vector" & then "vector 1" you get a
control panel.. The "fill areas" button will set color=none for the
filling, no way of setting it for the line color from the GUI that I
know of.Michael just implemented it:
http://grass.itc.it/pipermail/grass5/2004-December/016625.htmlHowever the vector.tcl attached to above mail conflicts with the latest
vector.tcl in CVS which includes management of new symbol directories...Michael (you probably know this better than I do, but just to make sure):
before you commit your change, you should check out the new version of
vector.tcl.Moritz
Is there a way of setting personal favorites from the Pallet color
selector? If not can we fill the 5 white boxes in the bottom row with
something? (nice task for a non-programmer: pick out some
non-represented R:G:B values)Hamish
____________________
C. Michael Barton, Professor of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
