Hail grass gurus!
I'm looking forward to checking out grass. It
seems pretty sophisticated.
I
installed 4.99+5.0.0pre4,
downloaded the global sample data set,
unzipped and untarred it,
ran "grass5 -tcltk" and
try to open the data set by pointing and clicking.
I get
Starting GRASS ...
The selected location is not a valid GRASS location
Suggestions?
Kingsley
I get
Starting GRASS ...
Suggestions?
Please be more specific about "pointing and clicking."
After you ran grass5 -tcltk, did you get a graphic dialog
box with sub-boxes for Database, Location, and Mapset?
Database
Where did you untar the global sample data set?
(Database should indicate the full path of its directory,
e.g., if global is in /home/user/grass/global, then Database
should indicate /home/user/grass)
Location
Does "global" appear as an option in the Location box? If
so, select it.
Mapset
Does "PERMANENT" appear as an option in the Mapset box? If
so, select it.
Hi Michael,
Thanks for replying.
Database should indicate /home/user/grass
You nailed it!
Now I just need to figure out how to actually see
a map....
Kingsley
