[GRASSLIST:5169] jpeglib.h
I am trying to install GRASS on a Dec Alpha Tru 64 machine. I have not been
allowed root permissions and so am installing in my own filespace.
When I originally configured using
./configure --prefix=/usr/d0/izzy/ --with-bindir=/usr/d0/izzy/
I got messages saying that the zlib and jpeglib includes could not be found. I
was able to install zlib and did not have the error message for this anymore. I
thought I had installed jpeg (v6b from ftp.uu.net/graphic/jpeg) but jpeglib.h
was not automatically put into my include directory when I used make install. I
have tried manually copying jpeglib.h from the untarred directory into the
includes directory but when I configure using
–with-zlib-includes=/usr/d0/izzy/include/ --with-zlib-libs=/usr/d0/izzy/lib/
–with-jpeg-includes=/usr/d0/izzy/include/ --with-jpeg-libs=/usr/d0/izzy/lib/
I still get the messages
checking for location of jpeg includes… /usr/d0/izzy/include
checking for jpeglib.h …no
configure:*** Unable to locate jpeg includes
What am I doing wrong?
BA flight sale now at www.lycos.co.uk New York, £129 rtn. including tax, Friday, 2pm
   been
   found. I
   anymore. I
   jpeglib.h
   install. I
   the
   --with-zlib-includes=/usr/d0/izzy/include/
   --with-jpeg-includes=/usr/d0/izzy/include/
   checking for location of jpeg includes... /usr/d0/izzy/include
   checking for jpeglib.h ...no
jpeglib.h also needs jconfig.h and jmorecfg.h; unless those files are
also present, the test will fail.
Also, JPEG isn't essential. No program requires it directly; you only
need it if you are using a version of the TIFF, GD or GDAL libraries
which themselver require JPEG. If you have problems, you can disable
the JPEG checks using configure's --without-jpeg switch (similar
switches exist for the other optional libraries).
