Hello all,
I just downloaded the latest CVS snapshot. Ran configure and then make and right from the get go I got linker errors due to the fact that some GRASS libraries could not be found. I saw on the snapshot download page a note that said GRASS 5.x source code is no longer needed to compile the CVS snapshot, so I figured that the snapshot would compile out of the box. Is this not the case? Do I need a working install of GRASS 5.4 to compile the 5.7 CVS code?
Eliot Cline
Hello Eliot,
On Thu, 16 Dec 2004 14:22:19 +0700 "Eliot Cline" <eliot@gospatial.com>
No, you dont. Please post your configuration and the resulting errors
here on the list so that we can give useful hints how to solve your
problems.
Stephan
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
