[GRASSLIST:5192] importing AutoCad .dxf files to GRASS 4.2
All,
I’ve been having problems importing 3 .dxf files (created in AutoCad Map (R) Release 2.0 as AutoCad R12/LT2 DXF files) into GRASS 4.2, using the v.in.dxf command. I am getting either a:
Ø bus error
or
Ø segmentation fault
error message. This results in only very small fragments of .dxf file contents being imported, without details of the files ‘drawing space’ (i.e. after running v.support, the opening screen in v.digit shows no values for the west/south/east/north edges of the map area). The file sizes of the .dxf files ranges from 1.2mb to 6.7mb. this problem persists no matter whether the .dxf files are AutoCad R12, R13 or R14. the .dxf files contain polyline entities. Initially I tried to export the cad file as a single .dxf, creating a series of vector files in GRASS based on the drawing layers. After the initial problems I broke the drawing up into a series of sub-drawings based on the individual layers. the oddity is that two of these new .dxf files have imported quite happily while the other 3 are causing the problems outlined above. Perplexing…
if anyone has any suggestions, has encountered these error messages before etc – I’d be very grateful to hear from you. Thanks,
Rob
Dr Robert Hosfield
Postdoctoral Research Fellow
Department of Archaeology
University of Southampton
Avenue Campus
Highfield
Southampton
SO17 1BJ
Telephone: +44 (0)23 8059 6864
Fax: +44 (0)23 8059 3032
E-mail: rth1@soton.ac.uk
Webpage: http://www.soton.ac.uk/~rth1/index.html
Flat 3
Nelric House
106-108 Kent Road
St Denys
Southampton
SO17 2LH
Telephone: 023 8058 1069
maybe persists for R12, R13 or R14, but I think that v.in.dxf
does not support higher version than 9 or 10.
You can use
http://sourceforge.net/project/showfiles.php?group_id=30996
to convert dwg<->dxf from any version to any other.
Radim
On Monday 09 December 2002 11:04 am, Dr Rob Hosfield wrote:
All,
I've been having problems importing 3 .dxf files (created in AutoCad Map
* bus error
or
* segmentation fault
contents being imported, without details of the files 'drawing space'
Perplexing.
before etc - I'd be very grateful to hear from you. Thanks,
Rob
Dr Robert Hosfield
Avenue Campus
Highfield
Southampton
SO17 1BJ
Flat 3
Nelric House
106-108 Kent Road
St Denys
Southampton
SO17 2LH
Content-Type: text/html; charset="us-ascii"; name="Attachment: 1"
Content-Transfer-Encoding: quoted-printable
Content-Description:
