I am a newbie at GISs and GRASS.
I am using GRASS 5.0.0 and need to convert a netCDF
format dataset to the raster format in GRASS.I suppose
one needs to gmake r.stage3 which doesnt come with
GRASS 5.0.0
How do i go about this process ? Do i need to download
some additional files ?
And how can i convert the raster form back to netCDF ?
any pointers ?
Vidya Kotamraju
__________________________________________________
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
http://mailplus.yahoo.com
Hello Vidya,
I know two ways to import netCDF files into GRASS.
1) You install R and you use R inside GRASS. R is able to read netCDF files, so you can export your variable in GRASS. I used this method six months ago and it worked fine.
2) An other option
You convert your netCDF file to an ascii file readable with the r.in.ascii command.
I prefer this option because it is less system resources consuming.
I made a shell script to convert netCDF file into GRASS raster ascii file but I use netCDF tools developed by my company and there are not publically available. However, if you are interested in, I can send it to you and I believe that it is easily portable with the nco tools (http://nco.sourceforge.net, have a look at ncks)
HTH
Paul
At 01:14 11/12/2002 -0800, vidya kotamraju wrote:
GRASS 5.0.0
any pointers ?
Vidya Kotamraju
Do you Yahoo!?
