[GRASSLIST:5231] USGSDEM export
Hi!
Any way to output a raster file in a USGSDEM format
from GRASS?. If I write
r.out.gdal in=mydem format=USGSDEM out=mydem.dem
the command returns:
Error: value <USGSDEM> out of range for parameter
<format>
       Legal range:
AAIGrid,BMP,BSB,DTED,ELAS,ENVI,FIT,GIF,GTiff,HFA,JPEG,MEM,MFF,MFF2,NITF,PAux,PNG,PNM,VRT,XPM
Listing all the available formats r.out.gdal
understands among other returns USGSDEM
r.out.gdal -l
USGSDEM: USGS Optional ASCII DEM (and CDED)
GRASS 5.7 compiled from cvs (4. 12. 2004), gdal-1.2.3.
Would a newer version of any solve the problem?
Thanks for your help, Miha Staut
___________________________________________________________
ALL-NEW Yahoo! Messenger - all new features - even more fun! http://uk.messenger.yahoo.com
On Mon, Dec 27, 2004 at 02:36:00PM +0000, we recorded a bogon-computron collision of the <mihastaut@yahoo.co.uk> flavor, containing:
Hi!
<format>
       Legal range:
r.out.gdal -l
I'm not exactly sure what the limitation is, but I've noticed that gdal
only partitially supports output of USGSDEM format. For example, when I
try to use the GDAL tool "gdalwarp" to convert a USGSDEM from NAD27 datum
to NAD83 datum, it tells me that the USGSDEM driver does not support direct
creation. However, if I gdalwarp from the source DEM in NAD27 to an
intermediate GeoTIFF in NAD83, then use gdal_translate to create a DEM
from the GeoTIFF, it does work.
So my guess is that if you really need USGSDEM output you could probably
do it by outputting to GeoTIFF and then using gdal_translate (not a
GRASS tool, it comes with the gdal library):
  gdal_translate -of USGSDEM intermediate.tiff Final.DEM
HTH,
T.
Tom Russo KM5VY SAR502 DM64ux http://www.swcp.com/~russo/
Tijeras, NM QRPL#1592 K2#398 SOC#236 AHTB#1 http://www.qsl.net/~km5vy/
"When life gives you lemons, find someone with a paper cut."
> Hi!
format
> <format>
> Legal range:
> r.out.gdal -l
gdal-1.2.3.
For example, when I
DEM in NAD27 to an
Final.DEM
HTH,
T.
Thanks Tom,
My only scruple is GeoTIFF would destroy the
information. Could that be true?
Miha Staut
> > Hi!
> format
> > <format>
> > Legal range:
> > r.out.gdal -l
> gdal-1.2.3.
> For example, when I
> DEM in NAD27 to an
> Final.DEM
> HTH,
> T.
Thanks Tom,
My reading of:
http://www.gdal.org/frmt_gtiff.html
suggests that you should be OK, the range of band types is pretty large,
and less problematic than USGSDEM:
http://www.gdal.org/frmt_usgsdem.html
Roger
Miha Staut
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand@nhh.no
On Tuesday 28 December 2004 01:18 am, Roger Bivand wrote:
----snip snip---------
> > Final.DEM
> > HTH,
> > T.
> Thanks Tom,
My reading of:
Roger
> Miha Staut
I have noticed this as well in trying to reproject a NAD27 DEM to a NAD83 DEM
via gdalwarp. I found that the datum conversion worked fine if I first
created an intermediate GTiff as Richard suggested. Since i was only
interested in getting the data into GRASS, the intermediate geotiff was
enough.
However, I had to manually set the USGS NODATA value left over from the DEM to
NULL in GRASS. I used r.mapcalc, but I imagine that r.null would work even
better.
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
