[GRASSLIST:5249] LSD program
In glancing at your script, I wondered why you didn't just import the
stuff into a statistical package like R and then use all the clustering
routines it has. See www.r-project.org
## Key commands in R are:
## Load the packages to access the database, in particular the PgSQL ##
database
require(Rdbi)
require(RdbiPgSQL)
## Load some clustering routines
require(cluster)
require(mclust)
### Connect to the database and read in a points data set "jogis"
## and read in the dataset "wells_att".
conn <- dbConnect(PgSQL(), dbname="jogis", user="caumann")
wells <- dbReadTable(conn, "wells_att")
dbDisconnect(conn)
## Now you can apply any clustering or kernel smoothing technique you
want to the dataset.
If this is of any help, let me know and I can provide more details.
Cheers!
Craig
Thanks Craig.
I realize that R has the potential to be a powerful statistical companion to
GRASS. The reasons I didn't use R for this LDA routine are:
1. I don't know R command syntax. This seems to be a fairly steep learning
curve, though I am sure the results are worth the effort. While I keep
thinking it would be useful to learn it, I have so much on my plate that I
simply haven't had time. I should learn C too. It would encourage me to
tackle R if it had a menu-driven interface to augment the command line, as I
am familiar with a variety of other stat packages (SPSS, Systat, Statistica,
and JMP--the latter being my package of choice in a large part because of
the UI). So far, I haven't found one that works on my Mac (a menu that
primarily lets me cut and paste commands, and open help files is nice but
not sufficient).
2. Most GRASS users don't know R command syntax. I suspect that many of them
will echo my comments in #1. The LDA routine I did is pretty simple to use.
Hopefully, this will make it more accessible to GRASS users.
3. I'm not clear about this, but it sounds from recent comments to the GRASS
developer's list like R will not currently read GRASS 5.7/6 vector data. The
commands you list below, suggest that you are working with GRASS 5.4 (or
earlier) vector data and an associated PostgreSQL database. I hope I am
wrong about this.
Finally, perhaps you could offer some advice given your knowledge of R. LDA
is not a clustering technique, but a way to quantitatively measure the to
what extent geospatial data are clumped or dispersed (along the lines of
nearest neighbor analysis but without some of the drawbacks of NN). Is there
such a routine in R? And are there modules that measure in other ways the
degree to which geospatial data are clumped or dispersed (evenly or
randomly)?
Thanks for the suggestion.
Michael Barton
database
require(Rdbi)
require(RdbiPgSQL)
require(cluster)
require(mclust)
dbDisconnect(conn)
Cheers!
Craig
______________________________
School of Human, Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
On Tue, 4 Jan 2005, Michael Barton wrote:
Thanks Craig.
not sufficient).
This is fair - although there are some GUIs being done (also using tcltk),
this isn't a priority for developers (or users) - see the R GUI link on
the side bar of the R home page http://www.r-project.org.
Maybe - the upside of writing a small R batch program is that the R
internals are heavily used, and most likely less exposed to coding error
than less used code. The downside is writing the code, though, and for
regular work done very often, an optimized GRASS module may execute
faster.
wrong about this.
You aren't right (nor wrong either as of now), 5.7/6 is certainly going to
be there, but as of now there have only been two specific requests for 5.7
vector support (in fact for points), and these can be handled through
reading and writing files. There is a lot of ongoing work on designing
robust spatial data classes for R, and they will make exchange though OGR
at least, possibly also with vector topology, much easier to code. Classes
first (we hope this month), then interface. 5.0.* and 5.4 raster and sites
continue to be supported, though the new compression style for integer
rasters is not yet there.
randomly)?
I haven't been able to get hold of the references you posted for LDA.
There are several packages including functions for testing cluster,
random, or dispersed. These cover the NN methods (Ghat, Fhat), but also
Khat, which seems like your method. Khat compares the relative intensity
of points in distance bands around each point (boundary adjusted) - I
would guess Johnson's method is based on the same use of the data. Brian
Ripley's "spatial" package permits rectangular window boundary adjustment,
splancs permits boundary adjustment in an arbitrary polygon, while
spatstat allows more options. One nice feature is that they all allow the
testing of results by simulation from completely spatially random and
other spatial processes.
The web references to LDA I have seen make it look as though the Khat
components (for each point) may be of interest - these are accessible in
the khat() function in splancs. I've seen mention of comparison of i and j
artefacts too - this looks like a marked point process, aka k12hat. If you
can feed me a specification and a test data set, I'll see if I can figure
out how this could be done, if you like.
Best wishes,
Roger
Michael Barton
> database
> require(Rdbi)
> require(RdbiPgSQL)
> require(cluster)
> require(mclust)
> dbDisconnect(conn)
> Cheers!
> Craig
USA
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand@nhh.no
Roger,
Thanks for the response. Craig sent me a chapter from the ADE-4 manual that
goes over the application of various versions of a Ripley's module. It does
indeed look like it is closely similar (identical?) to Johnson's LDA
routine.
It would be nice indeed to be able to access R routines from within GRASS
and have them act on GRASS data directly. If people could then start writing
a few scripts that incorporated R commands, they could give them a
reasonably nice GUI face using g_parser calls.
For testing my LDA script, I just used the bugsite and archsite points in
the Spearfish for 5.7 demo set.
Craig's email got me to thinking about ADE again as an interesting package
to re-look at. It has such a klunky and antiquated data structure though. I
don't know how it could read GRASS data.
Michael
Thanks Craig.
not sufficient).
faster.
wrong about this.
randomly)?
Best wishes,
Roger
Michael Barton
database
require(Rdbi)
require(RdbiPgSQL)
require(cluster)
require(mclust)
dbDisconnect(conn)
Cheers!
Craig
USA
C. Michael Barton, Professor of Anthropology
PO Box 872402
USA
Phone: 480-965-6262
Fax: 480-965-7671
