[GRASSLIST:5262] DFX import
I have been attempting to import a multi-layer DFX file into GRASS (vs
5), using v.in.dfx -a. The file was originally created in AUTOCAD and
then converted to DFX. I am able to open and view all layers of the
converted DFX file in Freehand 9. The import is partially successful;
however not all the contour layers import. They appear to stop at a
particular contour interval (although this is just a guess). To work
around the problem I tried to import another file of the same site with
the same contour layer. However in this import attempt, the contour
layer would not import at all. Are there particular commands for
importing contour layers? Any help or guidance anyone could offer would
be appreciated. Thanks.
Baylor University is currently experiencing E-mail problems. We cannot assure that your message will be delivered in a timely manner. You do not neeed to re-send your message, it has been safely recieved by our system for eventual delivery to the recipient. We intend to have our system fully restored by Monday, Jaunary 13.
