On Tuesday 11 January 2005 04:21 am, RAVI KUMAR wrote:
Will any body please suggest any online documentation
(html,pdf etc) to learn GRASS57 database management
and query efficiently.
Ex: I use a vector file with 100 areas involving 10
attributes. How to generate a map with only a couple
of attributes, with a query or something.
Ravi
you can do this in a couple of ways.
1. display vectors based on their CAT
2. display vectors based on some attribute
3. create a table in the RDBMS of your choice, and use this for deciding which
vectors to display.
I haven't been able to get the db.execute command to work on DBF files, so I
can't help much there. Also the 'where' option in d.vect doesn't seem to do
what I want either (operator error?)...
I have been creating tables in MySQL and using them as a basis for what I want
displayed. For more information on DB stuff, see the GRASS WIKI.
You can extract vector features to new map in GRASS 5.7 with the
v.extract module. see also v.select, v.in.region+v.overlay, etc
deciding which vectors to display.
files, so I can't help much there.
works fine for me. see the v.in.garmin script.
Also the 'where' option in d.vect doesn't seem to do what I want
