Hi, I am trying to overlay to vectorial (area) maps, mapa1 and mapa2 but
without success:
# v.db.connect -p mapa1
Vector map <mapa1> is connected by:
field <1> table <mapa1> in database
</home/marta/grassdata/espanya_modelo_devel/pred_ppinea/dbf/> through
driver <dbf> with
key <cat>
# v.db.connect -p mapa2
Vector map <mapa2> is connected by:
field <1> table <mapa2> in database
driver <dbf> with
key <cat>
BUT:
# v.overlay ainput=mapa1 binput=mapa2 output=output operator=and
Writing attributes ...
Copying ainput lines ... 100%
Copying binput lines ... 100%
Buiding partial topology ...
Breaking lines ...
Intersections: 6427
Removing duplicates ...
Duplicates: 30
Cleaning boundaries at nodes ...
Modifications: 0
Attaching islands ...
Building topology ...
Building areas: 100%
1869 areas built
986 isles built
Attaching islands: 100%
Topology was built.
Number of nodes : 8771
Number of primitives: 11422
Number of points : 0
Number of lines : 0
Number of boundaries: 11422
Number of centroids : 0
Number of areas : 1869
Number of isles : 986
Number of areas without centroid : 1869
Querying input 'mapa1@pred_ppinea' ... Segmentation fault.
Any ideas?
Many thanks
First try to update GRASS, your version is almost 2 months old.
Radim
without success: # v.db.connect -p mapa1
driver <dbf> with
key <cat>
driver <dbf> with
key <cat>
BUT:
Breaking lines ...
Intersections: 6427
Duplicates: 30
Modifications: 0
1869 areas built
986 isles built
Topology was built.
Number of lines : 0
Any ideas?
Many thanks
I have update GRASS, and the problem is still appearing, without writing
anything :
Segmentation fault
thank you
Radim
> without success:
> driver <dbf> with
> key <cat>
> driver <dbf> with
> key <cat>
> BUT:
> Breaking lines ...
> Intersections: 6427
> Duplicates: 30
> Modifications: 0
> 1869 areas built
> 986 isles built
> Topology was built.
> Number of lines : 0
> Any ideas?
> Many thanks
anything :
Segmentation fault
thank you
I wonder if this is in any way related to the Segfaults that v.out.ascii is
causing...
Attached is the output from strace v.out.ascii
Dylan
> Radim
> > but without success:
> > driver <dbf> with
> > key <cat>
> > driver <dbf> with
> > key <cat>
> > BUT:
> >------ Writing attributes ...
> >------ Copying binput lines ... 100%
> >------ Buiding partial topology ...
> >------ Breaking lines ...
> > Intersections: 6427
> >------ Removing duplicates ...
> > Duplicates: 30
> >------ Cleaning boundaries at nodes ...
> > Modifications: 0
> >------ Attaching islands ...
> > 1869 areas built
> > 986 isles built
> > Topology was built.
> > Number of lines : 0
> >------ Querying input 'mapa1@pred_ppinea' ... Segmentation fault.
> > Any ideas?
> > Many thanks
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
(attachments)
strace.log (25.6 KB)
