[GRASSLIST:5297] using GRASS in Emacs environment
Dear all,
I began to use GRASS GIS on Linux recently. I'm using some scientific
computing softwares in the environment of Emacs so far. Therefore, I
want to use GRASS on emacs. Does anyone know an interface between the
user and GRASS on emacs? Is there the emacs-lisp program which
provides the emacs major mode?
For example, there is the ESS (Emacs Speaks Statistics), which inter-
faces with S-Plus, R, SAS and so on, for statistical computing.
Thank you.
Masaei Sato <masaei@tohoku.interq.or.jp>
I'm not aware of any Emacs facilities for GRASS specifically (I use
XEmacs for most of my work, so I would certainly have taken note if I
had heard of anything). There is an R interface to GRASS, which would
presumably work with ESS.
One hint: if you wish to use GRASS from within an Emacs shell-mode
buffer, you can bypass the curses-based startup screen by passing the
complete path to the mapset directory as an argument to the "grass5"
script. I.e.
  grass5 /opt/grass-data/spearfish/glynn
has the same effect as running "grass5" without arguments and entering
the following in the startup screen:
  MAPSET: glynn
  DATABASE: /opt/grass-data
Unfortunately, a few programs (primarily v.digit and many of the
imagery programs) can only be used through a curses-based interface,
which won't work with shell-mode. term-mode should work, but that
"eats" most of Emacs' common keystrokes, which substantially reduces
its usefulness, IMHO.
Dear Clements,
Thank you very much for your answer.
Yes certainly, there is the GRASS/R interface which is able to working
with ESS. (I was suggested that by Mr. Furlanello in the statsgrass
mailing list.)
If the inherent commands of GRASS is available within the GRASS/R
interface, that is enough for me. But I don't know whether that is
possible or not.
I will use GRASS with shell-mode of emacs for the present.
