Hi to all
I tried to use v.surf.rst!!!
I have to create a higth resolution DEM (1 m raster cells) of the landscape
along a river....
the problem is that this river has an oblique path on the screen, from NO to
SE....
So, setting the region of the study area to match the river path, I
interpolate a lot of landscape I don't need.... with obvious problem of time
to obtain the results...
because I have georeferenced aerial photos of the river I tried to use the
mask option of v.surf.rst, setting the mask to match a single photo, but I
didn't obtain good results... and the same using the MASK option of grass....
I also tried to use the procedure explained in the book Open Source
Gis.........(Neteler-Mitasova) about the generation of a dem in a surface
with faults (gully.mask, etc......).
but I didn't understand why they use an inverse mask to obtain only the DEM of
the gully.....
They have a gully area named "gully.mask" and a lot of points of the gully
topografy "gully.ascii"
They transform the ascii file in site grass data:
s.in.ascii elev.gully input=gully.ascii
after, they obtain the inverted mask:
r.mapcalc gully.mask.inv = "if(gully.mask,0,1)"
then, they use s.surf.rst:
s.surf.rst elev.gully elev=elev.gully mask=gully.mask.inv
They say that in this way is possible to interpolate only in the area of the
gully and not in the hillslope around....
The problem is:
the raster gully.mask.inv is a map that have value 0 inside the area of the
gully and 1 outside....
so, I think that, using the antecedent sintax, I obtain an opposite result
Can someone help me??
Thank you and sorry for the lenght of the e-mail.....
Ivan
can someone help me???
