[GRASSLIST:5312] GRASS5_mapserver and GRASS/Postgre
Hello
2 questions :
1-Grass5_mapserver
I have been trying for 24 hours the 5 minutes grass5_mapserver
installation ...with no result!
compilations done :
freetype-2.0.5, gd-2.0.9, proj-4.4.5,libgrass5-1.0.0,w3c-libwww-5.4.0,gdal-
1.1.8
and mapserver-3.6.3
http://localhost/start.html can find the mapserver.map
when i select any of the options, the URL becomes :
http://localhost/cgi-bin/mapserv?
mode=browse&layer=soils&mode=browse&zoom=1&imgxy=250.5+200.5
&imgext=590000.000000+4913392.000000+609000.000000+4928608.000000
&map=%2Fusr%2Flocal%2Fhttpd%2Fhtdocs%2Fmap-script%2Fmapserver.map
the only information I can find is the following error_log of Apache :
File does not exist: /usr/local/httpd/htdocs/tmp/GRASSsb10426475507950.png
(Directories and Aliases have been checked, as well as permissions; the
refmap.png can be seen
from the spearfich directory under htdocs)
Is there any other error log specific for mapserver and where to find them ?
2-Grass/postgres
I used the v.to.pg and d.vect.pg as described by A.Shevlakov
when I tried d.vect.pg -e I got "the -e is not a valid flag" ???
The v.to.pg -f with sql is working well. But...I don't know how to save the
outgoing map in a file.
I can see no output option for v.to.pg.
The v.reclass.pg asks for an existing vector file for input....my file is not
existing yet!
My question is how to save this map displayed in the monitor?
I'm supposed to have all this working by the end of the week...(student
exam)...or later (personnal satisfaction)
Thank you for your help(s)
Shirley
On Wed, Jan 15, 2003 at 07:11:11PM +1100, shgervo@offratel.nc wrote:
Hello
2 questions :
1-Grass5_mapserver
compilations done :
1.1.8
and mapserver-3.6.3
As far as I know there is only error_log which holds all errors.
Are you sure that Apache is allowed to read the .grassrc5 file? Is it in
the right place? See the README for libgrass5-1.0.0 for some details.
regards
Markus Neteler
