Hello;
I've got a sites file (imported with s.in.ascii) with 1165 rows (points). If
I display the map or execute s.out.ascii, I just get the first 61 lines. For
every point there are 13 real attributes and one text attribute.
Could this be an error of these programs ought to the big sites file?
Thanks and regards
A. Javier García
Water and Soil Conservation Department
CEBAS-CSIC
Apartado 4195
30080 Murcia
Spain
Tel.: +34 968 39 63 90
Fax: +34 968 39 62 13
On Fri, Jan 17, 2003 at 09:19:05AM +0100, javier garcia - CEBAS wrote:
Hello;
The most likely cause is an "error" in the file such as a missing field.
I'd wager you have a missing text field near the 62nd entry.
Unfortunately, the sites format does not accomadate empty strings or
other null values. Changing empty text fields to something like "N/A"
or "(null)" or whatever can help.
echo ">gra.fcw@2ztr< eryyvZ .T pveR" | rot13 | reverse
