Will somebody help me to add the latest grass57 csv
without jeopardising my long time achievement of
installing grass csv, using
grass-5.7.cvs-i686-pc-linux-gnu-25_12_2004-install.sh
Do I have to wage the battle again, of correcting
errors and file missmatches using commands like
ln -s /usr/lib/libtk.so /usr/lib/libtk.so.0.
Once system dependancies are met the first time, they generally will not
change much. (ie upgrading is much easier than initial install)
Iam a bit apprahencive, and I will wait until I get a
favourable mail giving me confidence.
Think of it as a chance to learn more about UNIX
Earlier I have received a feed that 'e00' file import
error of GRASS57 is corrected(a typo v00 to e00),
after I have indicated the same.
Don't know if it worth upgrading for a simple message typo..
If built from source, just cd into the module's directory and
run 'cvs update' [*] then make to rebuild an individual module.
[*] may need to run 'cvs login' first, see the CVS page on the GRASS
website.
