[GRASSLIST:5346] need help with ps.map
I'm trying to produce a map with ps.map but the colortable doesn't show. why
could it be?
thanks all for help.
   Carlos Henrique Grohmann de Carvalho - Guano
     Geologist - MSc Student IGc-USP - Brazil
   Linux User #89721 PGP key: www.keyserver.net
show. why could it be?
If you're using GV, try manually selecting a specific page size; using
the "BBox" option will only show the map, and not anything else which
is on the page (this is a bug in ps.map).
