[GRASSLIST:5350] thanks but ps.map still doesn't work
Thanks for your answer, Glynn but ps.map still doesn't work. I selected a a4
ps device, but all I get is a "no data" and a blank square below the map.
Already tried to open in GV, GIMP and all the same.
Symposium dead line is coming and maps aren't ready...
Thanks
   Carlos Henrique Grohmann de Carvalho - Guano
     Geologist - MSc Student IGc-USP - Brazil
   Linux User #89721 PGP key: www.keyserver.net
Another issue is that the colour table only includes categories which
have a label. If there are only a few categories, you can use
r.support to manually add labels. If there are too many categories to
do this, you could write a script to add dummy labels to the cats file
(<gisdbase>/<location>/<mapset>/cats/<mapname>).
