[GRASSLIST:5352] Re: thanks but ps.map still doesn't work
Hey! Now its working.
ps. the hints you wrote should be in the man page.
thanks
Em 22 Jan 2003, Glynn Clements escreveu:
Carlos Henrique Grohmann de Carvalho wrote:
Thanks for your answer, Glynn but ps.map still doesn't work. I selected a
a4
ps device, but all I get is a "no data" and a blank square below the map.
Another issue is that the colour table only includes categories which
have a label. If there are only a few categories, you can use
r.support to manually add labels. If there are too many categories to
do this, you could write a script to add dummy labels to the cats file
(<gisdbase>/<location>//cats/).
   Carlos Henrique Grohmann de Carvalho - Guano
     Geologist - MSc Student IGc-USP - Brazil
   Linux User #89721 PGP key: www.keyserver.net
