I want to use a color composite in order to select
signature sites. The thing is, when I create the color
composite with i.composite the colors comes too dark,
differente from when I display them with d.rgb. The 3
images used have a grey.eq color table...
Thanks
Daniel
__________________________________
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
http://sbc.yahoo.com
d.rgb uses the map's colour table, i.composite doesn't.
Try using r.rescale.eq to equalise the actual category values rather
than the colour table.
