[GRASSLIST:5390] Script to 'sample' several grids with result saved to text output?
Dear R-geo and GRASS users,
-Before trying to reinvent the wheel I would like to check whether someone has tried this before.-
I have several rasters with environmental data. I also have point data, representing animal locations (collected with GPS collars).
I would like to use GRASS to 'sample' (apologies for the ArcInfo AML terminology, but it might help people to get what I need) the rasters with the point data and save the results in a text file for further analysis with R.
The resulting text file should contain a field/attribute of my choice from the points data file (some sort of ID for each point) and a field/attribute for each of the sampled rasters.
Preferably I would use an R script that calls GRASS, as both point data collection and further analysis is done within R. However a GRASS script working on input and output text files might also be sufficient.
Any help would be much appreciated,
Sander Oom.
PS: I am a total novice with GRASS.
analysis with R.
this script should do the work, just copy it into a txt file (make it
executable) and replace "rast1 rast2 ..." with your raster image names.
if you execute inside GRASS
sh name_of_text_file
you will be prompted to add you base file (your location file - must be a
raster not a vector file - just use v.to.rast).
your output will be csv files corresponding to your input raster images.
Finally you can just read these files into R via read.csv(). Be aware that all
raster values were multiplied with factor 100000, just divide you results in
R by 100000.
hope this script is what you want, probably there does also a direct-R-GRASS
solution exist, cheers Martin
#!/bin/bash
# read in location file
echo -n "enter base ->"
read base
site=$base
#enter names of your raster files
for raster in rast1 rast2 rast3; do
r.mapcalc "rast1=int($raster*1000000)"
r.statistics base=$site cover=rast1 method=average out=rastavg
g.remove rast=rast1
#writing data to csv file
r.stats -l rastavg>>$raster.csv
g.remove rast=rastavg ; done
MESSAGE="finished"
echo $MESSAGE
analysis with R.
Something like the following works with GRASS 5.4 and R 2.0.1, using the
spearfish test data set for GRASS 5.3:
rtmp <- tempfile()
system(paste("s.out.ascii bugsites | r.what -f vegcover,geology >",
+ rtmp))
system(paste("tail -5", rtmp))
601228|4917635||5|mixed forest|5|limestone
603146|4917453||3|coniferous forest|5|limestone
605627|4916428||3|coniferous forest|5|limestone
607098|4917437||3|coniferous forest|4|sandstone
608471|4915733||3|coniferous forest|8|claysand
input <- scan(rtmp, sep="|", what=list(x=numeric(0), y=numeric(0),
+ NULL, NULL, vegcover=character(0), NULL, geology=character(0)))
Read 90 records
str(input)
List of 7
$ x : num [1:90] 590232 590430 590529 590546 590612 ...
$ y : num [1:90] 4915039 4915204 4914625 4915353 4915320 ...
$ : NULL
$ : NULL
$ vegcover: chr [1:90] "coniferous forest" "coniferous forest"
"coniferous forest" "coniferous forest" ...
$ : NULL
$ geology : chr [1:90] "igneous" "igneous" "igneous" "sandstone" ...
input1 <- data.frame(input[c(1,2,5,7)])
str(input1)
`data.frame': 90 obs. of 4 variables:
$ x : num 590232 590430 590529 590546 590612 ...
$ y : num 4915039 4915204 4914625 4915353 4915320 ...
$ vegcover: Factor w/ 4 levels "coniferous forest",..: 1 1 1 1 1 4 1 1 1 1
$ geology : Factor w/ 5 levels "claysand","igneous",..: 2 2 2 5 5 5 5 3 2 5
If I had figured out how to read the output of r.what into s.in.ascii,
storing the data as a sites file, then using the R GRASS package and
sites.get() would have been neater, but this does work.
Hope this helps,
Roger Bivand
Sander Oom.
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand@nhh.no
analysis with R.
sufficient.
r.what does this nicely:
http://grass.ibiblio.org/grass57/manuals/html57_user/r.what.html
I guess r.what could/should be modified to read from a sites (vector
points) list and write to a new sites (vector points) list with queried
attributes. (currently just pipe from stdin & to stdout)
Easy to do in a script I guess.
Roger:
I don't think that would be too hard with GRASS 5.7/6:
v.in.ascii input=r_what_output.txt fs=',' cat=1 x=2 y=3
GRASS 5.0/5.4's s.in.ascii needs to rearrange column order though with
UNIX 'cut' and 'paste' commands first?
Hamish
analysis with R.
Sander Oom.
In the past I have used 's.sample' in GRASS54 to "sample" many rasters at
given site locations...
here is some sample code:
#export digitized gras57 vectors as sites (from GRASS57):
s.out.ascii input=b_sites > b_sites.xy
#load exported grass57 vector sites (GRASS53):
s.in.ascii sites=beam_sample_sites input=b_sites.xy
#sample the rasters in a for loop!
for x in `seq 1 364`; do a=`s.sample input=beam_sample_sites \
rast=beam$x -q -C | awk -F"%" '{ORS = " "}{print $2}'`; echo $x $a \
; done > data.out
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
Isn't this functionality already there?
http://grass.itc.it/grass60/manuals/html60_user/v.what.rast.html
