Hi Jitendra,
A small help to find out information about your files
without GRASS would be to use GDAL, that is a
prerequisite to installing GRASS.
Gdalinfo /path/imagename.extension >
/path/imagename.txt
This would create a small text file named
'imagename.txt' that is compiling projection
information and related stuff.
Yann Chemin
Asian Institute of Technology, Bangkok
__________________________________________________
Do You Yahoo!?
Everything you'll ever need on one web page
from News and Sport to Email and Music Charts
http://uk.my.yahoo.com
On Fri, Jan 31, 2003 at 01:49:04AM +0000, Yann Chemin wrote:
Hi Jitendra,
/path/imagename.txt
For those being interested I have written a small script
based on r.in.gdal which generates a new location from
a raster data set.
This script will temporarily start GRASS and generate
the location, then it closes the GRASS session.
http://mpa.itc.it/markus/useful/
-> create_grass_location.sh
Script to create a new LOCATION from a raster data set
Usage:
create_location.sh rasterfile newlocation_name [GISDBASE]
rasterfile: file to be imported (tiff, EOSAT, gif, jpeg...)
newlocation_name: new location to be created
GISDBASE: full path to GRASS database directory (optional)
e.g. /ssi0/ssi/neteler/grassdata
Best regards
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
Project on Predictive Models for the Environment
Via Sommarive, 18 - 38050 Povo (Trento), Italy
tel +39 0461 314 520 (fax -591) http://mpa.itc.it
