[GRASSLIST:5418] Difference between using precompiled binaries and compiling source code!
dear list,
i´m using grass54 binaries. what´s the difference between using precompiled binaries and compiling source code! (for all grass versions).
lg
michaela
Institut fuer Geographie und Regionalforschung
Universitaet Wien
Kartografie und Geoinformation
Departement of Geography and Regional Research
University of Vienna
Cartography and GIS
Universitaetstr. 7, A-1010 Wien, AUSTRIA
Tel: (+43 1) 4277 48646
Fax: (+43 1) 4277 48649
E-mail: kinb@atlas.gis.univie.ac.at
WWW: http://www.gis.univie.ac.at/karto
On Tue, January 18, 2005 13:02, Michaela Kinberger said:
dear list,
If you want to be able to modify some module or just recompile one particular
module after someone has posted a bugfix for it, then you should compile from
source code as you can then selectively update the parts you want.
If you don't think you need/want to do that, the precompiled binaries are
definitely easier to install.
Moritz
