Subject: Re: [GRASSLIST:5408] v.in.dgn compile with error (new error)
Date: Mon, 3 Feb 2003 17:01:52 +0100
From: Miguel Cordero <mcordero@lugo.usc.es> (by way of Miguel Cordero
<migcordero@yahoo.es>)
To: GRASSLIST@baylor.edu
Cc: warmerdam@pobox.com
El Jue 30 Ene 2003 22:14, escribió:
I'm getting error when compile v.in.dgn.
I used grass50src_cvs_snapshot_exp_2003_01_24.tar.gz and gdal-1.1.8.tar.gz
too, but error continue:The file "cpl_conv.h" is missing;
miguel@kiwi:~/tmp/grass50_exp_2003_01_24$ gmake5 -i src/mapdev/v.in.dgn
SRC = /home/miguel/tmp/grass50_exp_2003_01_24/src
CMD = /home/miguel/tmp/grass50_exp_2003_01_24/src/CMD
UNUSED = /home/miguel/tmp/grass50_exp_2003_01_24/unused
HEADER = head.i586-pc-linux-gnu
ARCH = i586-pc-linux-gnu
GISBASE = /home/miguel/tmp/grass50_exp_2003_01_24/dist.i586-pc-linux-gnu
VERSION = 5.0.1-cvs October 2002
/home/miguel/tmp/grass50_exp_2003_01_24/src/mapdev/v.in.dgn
make -f OBJ.i586-pc-linux-gnu/make.rulesgcc -I/home/miguel/tmp/grass50_exp_2003_01_24/src/include -g -O2 -c
main.c -o OBJ.i586-pc-linux-gnu/main.o
Thanks, now this is OK.
but... I get a new error !!!
I tried with
gdal-1.1.8.tar.gz in http://remotesensing.org/gdal/
dgnlib-1.6.zip in http://gdal.velocet.ca/projects/dgn/
but the result is the same.
With grass5.0.1 and grass50_exp_2003_01_24 there are some differences, but
talk about the same funcitions.
Miguel
With grass5.0.1:
--------------- miguel@kiwi:~/tmp/grass5.0.1/src/mapdev/v.in.dgn$ gmake5 -i
SRC = /home/miguel/tmp/grass5.0.1/src
CMD = /home/miguel/tmp/grass5.0.1/src/CMD
UNUSED = /home/miguel/tmp/grass5.0.1/unused
GISBASE = /home/miguel/tmp/grass5.0.1/dist.i586-pc-linux-gnu
VERSION = 5.0.1 January 2003
/home/miguel/tmp/grass5.0.1/src/mapdev/v.in.dgn
gcc -I/home/miguel/tmp/grass5.0.1/src/include -g -O2 -c main.c -o
main.c: In function `main':
main.c:142: too few arguments to function `DGNOpen'
make: *** [OBJ.i586-pc-linux-gnu/main.o] Error 1
and with grass50src_cvs_snapshot_exp_2003_01_24.tar.gz
miguel@kiwi:~/tmp/grass50_exp_2003_01_24/src/mapdev/v.in.dgn$ gmake5 -i
gcc -L/home/miguel/tmp/grass50_exp_2003_01_24/src/libes/LIB.i586-pc-linux-gnu
-o
/home/miguel/tmp/grass50_exp_2003_01_24/dist.i586-pc-linux-gnu/etc/bin/cmd/v.
in.dgn OBJ.i586-pc-linux-gnu/main.o -lvect -ldig2 -lgis -ldl -lm -lz
OBJ.i586-pc-linux-gnu/main.o: En la función `main':
/home/miguel/tmp/grass50_exp_2003_01_24/src/mapdev/v.in.dgn/main.c:164:
referencia a `DGNOpen' sin definir
/home/miguel/tmp/grass50_exp_2003_01_24/src/mapdev/v.in.dgn/main.c:170:
referencia a `DGNClose' sin definir
/home/miguel/tmp/grass50_exp_2003_01_24/src/mapdev/v.in.dgn/main.c:176:
/home/miguel/tmp/grass50_exp_2003_01_24/src/mapdev/v.in.dgn/main.c:194:
referencia a `DGNGetElementIndex' sin definir
/home/miguel/tmp/grass50_exp_2003_01_24/src/mapdev/v.in.dgn/main.c:202:
referencia a `DGNFreeElement' sin definir
/home/miguel/tmp/grass50_exp_2003_01_24/src/mapdev/v.in.dgn/main.c:204:
referencia a `DGNReadElement' sin definir
/home/miguel/tmp/grass50_exp_2003_01_24/src/mapdev/v.in.dgn/main.c:211:
OBJ.i586-pc-linux-gnu/main.o: En la función `read_element':
/home/miguel/tmp/grass50_exp_2003_01_24/src/mapdev/v.in.dgn/main.c:248:
referencia a `DGNGetLinkage' sin definir
/home/miguel/tmp/grass50_exp_2003_01_24/src/mapdev/v.in.dgn/main.c:302:
referencia a `DGNStrokeArc' sin definir
/home/miguel/tmp/grass50_exp_2003_01_24/src/mapdev/v.in.dgn/main.c:321:
referencia a `DGNStrokeCurve' sin definir
/home/miguel/tmp/grass50_exp_2003_01_24/src/mapdev/v.in.dgn/main.c:425:
referencia a `DGNTypeToName' sin definir
/home/miguel/tmp/grass50_exp_2003_01_24/src/mapdev/v.in.dgn/main.c:429:
collect2: ld returned 1 exit status
make: ***
[/home/miguel/tmp/grass50_exp_2003_01_24/dist.i586-pc-linux-gnu/etc/bin/cmd/v
.in.dgn] Error 1
