[GRASSLIST:5472] Text files, invalid points
thanks for you help with my PONET query- didn't manage to find source online, but found they convert (v.to.rst) with no problems.
I now need to produce a surface from a text file (sites). This is bathymetric data, so any positive value is erroneous. What is the best (easiest) way to find and remove such values, given that the file i too big to display in one go in spreadsheets such as excel?
Alternatively, is there a way to tell Grass to ignore these values when interpolating the surface?
Lawrence
Arrays which are too big for excel usually load into matlab/octave
without a problem. Easy to fix flipped numbers too:
for i = 1:length(depth)
  if( depth(i) > 0 )
     depth(i)=depth(i)*-1;
  end
end
GRASS 5.4:
probably running an awk script on the sites or input text file?
maybe
grep -v '%-' sites_map
GRASS 5.7:
v.extract where="z < 1"
If the positive values are really land, they are probably worth leaving
in to help get the slope of the shore correct..? (you can always use
r.mapcalc to cut out positive elevations later)
Hamish
