[GRASSLIST:5477] Re: grass60 in command line?
My apologies, since your question was in reply to my post on hexadecimal colors, I thought your were making a connection between the two.
On Jan 21, 2005, at 2:15 PM, samuel cavalcante wrote:
well,
my very poor third world english...
No worries
and my poor knowledge of computer stuffs...
don't we all...
can i not use the grass60 graphic interface...?
yes
is it possible run grass60 without any graphic interface?
yes.. for the most part
i tried to use the command line but always a box appears to be clicked....
What commands are you trying to run. most grass modules can run either with a GUI or from the command line (a few such as v.digit and a few of the image modules) require a gui). Let the list know what modules you are trying to run and I (or someone with more experience than I) will try and help.
clear?
it´s more comfortable to me use the keyboard ...
thanks
samuel
"Kirk R. Wythers" <kwythers@umn.edu> wrote:
On Jan 21, 2005, at 11:47 AM, samuel cavalcante wrote:
> hi,
> i´d like do run grass60 interactively and/or non-interactively in
> terminal command line mode..is that possible?
What are you trying to say here?
> samuel
> "Kirk R. Wythers" wrote:
> Can anyone tell me if GRASS can deal with hexadecimal color codes
> (something like 0100FFAA)? I have a ascii vector file that contains
> hexadecimal color codes for the lines and polygons. I am writing a
> small program that converts that ascii vector file (which was output
> from another gis package) into the v.in.ascii format, and I wonder if
> I
> can retain that information.
> Thanks,
> Kirk
> Kirk R. Wythers
> Dept. of Forest Resources
> University of Minnesota
> email: kwythers@umn.edu
> tel: 612.625.2261
> fax: 612.625.5212
Kirk R. Wythers
tel: 612.625.2261
fax: 612.625.5212
clicked....
try and help.
If you type just the name of the command without any flags or options you will
get the GUI "box". If you type the command with options, you will not the GUI.
Moritz
