GRASS raster -> other GIS:
A good (rather new) option to exchange data is to go via standard
raster files such as GeoTIFF etc.
GRASS 6 provides a script 'r.out.gdal' which writes valid
GeoTIFFs (also other formats, see:
http://grass.itc.it/grass60/manuals/html60_user/r.out.gdal.html
It is a wrapper script around the excellent 'gdal_translate' tool.
Requirements are GDAL to be installed, with GRASS support
compiled in (GDAL now comes with an own driver/plugin which
links to the GRASS 6 libraries, no need to compile the
dated 'libgrass').
Configuration scripts (especially for the GRASS/GDAL plugin)
I can make available.
SuSe users may go here for SRPMs/binary RPMS:
http://www.gdf-hannover.de/software/suse/9.1/
Regards
Markus Neteler
On Fri, Jan 21, 2005 at 06:07:29PM -0500, William W. Hargrove wrote:
A colleague with whom I've tried to exchange a tarfile of a GRASS mapset
says that the venerable old GISDBASE env variable/"imagegrid" method of
transferring files no longer seems to work with the new ArcGIS (and this is
all that he has).
If true, ESRI has actually *removed* functionality with this latest product.
Can anyone verify or correct this?
Any other suggestions for GRASS raster to Arc grid transfers?
Bill H.
William W. Hargrove hnw@fire.esd.ornl.gov
Environmental Sciences Division (865) 241-2748
Oak Ridge National Laboratory (865) 574-4665 (fax)
P.O. Box 2008, M.S. 6407 http://research.esd.ornl.gov/~hnw
Oak Ridge, TN 37830-6407 FedEx/UPS, use "Bethel Valley Rd."
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
