[GRASSLIST:5481] attributes in vectors
Between GRASS5.3 and GRASS5.7 Vector queries are vastly improved.
Even the containment of ‘points in areas’, to make a sub-set is well done.
Bravo, well done.
Scope for further improvement VECTOR:
while issuing sql queries… WHERE “ATTRIB=‘ABC’”
THAT IS Attributes with text vectors
it is very useful to
  1. filter out attribute text column for number of UNIQUE attributes.
    Ex: abc,def,ghi are 3 attributes in a attributetext column, but repeat 10s of times.
  2. So if a menu opens with the the number of UNIQUE attributes, for selection
    then the SQL Queries can be framed effortlessly.
    Presently Iam opening the DBF attribute file in opeoffice and sorting out the
    TEXTATTRIBUTE column to find the unique occurrences.
This kind of tool is available in arc-info.
Thanking U in advance
Ravi
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
