[GRASSLIST:5496] RE: Can't resize monitor.
Matt Doggett wrote:
Problem: Using Grass5.0, we cannot resize the Xwindow monitor created
using d.mon.
2. Several people have reported a "d.resize" command.
or more generally d.monsize: [broken in 5.0.0, fixed in CVS]
USAGE: d.monsize <monitor_width> <monitor_height> <monitor_name>
It lets you specify a specific monitor too, otherwise seems to be
redunant with d.resize.
Glynn Clements wrote:
The initial size of a monitor is determined by the GRASS_WIDTH and
GRASS_HEIGHT environment variables, e.g.
      GRASS_WIDTH=512
      export GRASS_WIDTH
      GRASS_HEIGHT=384
      export GRASS_HEIGHT
which is right,
while John Gillette wrote:
In html man pages under Drivers -> XDRIVER :
XDRIVER_WIDTH=xxx
XDRIVER_HEIGHT=yyy
XDRIVER_LEFT
XDRIVER_TOP
which are now wrong.
John again:
If you use the TCLTK menus:
Config (on the very left hand side) ->Options ->Display dimensions
This seems to be broken in 5.0.0 as well as CVS.
(/src/tcltkgrass/main/gui.tcl)
so off I go to file two more bugs..
Hamish
