[GRASSLIST:550] line to area
I created a line with v.digit and I now want to convert it to an area. Seems like a simple question, but how do I do it?
Rich
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
Rich@GreenwoodMap.com
(307) 733-0203
http://www.GreenwoodMap.com
Thanks to Erin O'Doherty and John Dougherty for the quick replies. My mistake was that I had not labeled my area in v.digit. All I wanted was a MASK, so I wasn't thinking about labels. But v.to.rast was expecting a label.
Thanks for the help guys.
Best regards,
Rich
> Thanks,
> Rich
Rich,
You need to snap the starting and ending nodes together. I have
not had much to do with digitizing in GRASS, however, v.digit is
probably the tool to use. The snap distance should be set to
force nodes together that are within the error of the map, which
for USGS maps is 0.002. Neteler and Mitasova discuss this in
their book.
John Dougherty
(307) 733-0203
I don't know if this could help you but I hope...
if the line is snapped on itself, try v.line2area.....
then try v.alabel to assign a category number to the area and after this try
v.to.rast...
I think this can be a solution....
bye
Ivan
label.
Best regards,
Rich
> > Thanks,
> > Rich
>Rich,
>their book.
>John Dougherty
(307) 733-0203
Ivan Marchesini
University of Perugia
v.line2area
r.in.poly might be an easier way to get what you want?
Hamish
I have a vector point dataset (ascii XYZ, the basis of a DEM).
I'm importing into GRASS5.7 with
cat <file> | v.in.ascii -Z output=nzxyz xcol=1 ycol=2 zcol=2 catcol=0
There are about 4,000,000 XYZ points.
The vector coor file is 150Mb. GRASS is now building the topology & index.
The topo file is almost 200Mb and the sidx is at 430Mb and growing.
Is this normal? It seems very excessive for a point dataset. A spatial
index & topology make more sense for line/polygon data, with over 4x the
actual data volume to store this extra info doesn't look right somehow...
The system is a SuSE Linux 9.1 23 bit OS on A64 3500 with 1Gb memory.
Swapped out 1.4Gb & still using 800Mb main memory.
Any advice appreciated....
  Brent Wood
It is normal.
Spatial index is important also for points, I think. Otherwise v.distance for example
must always go through all points. Say that you have another vector with 4,000,000
and you want to find the nearst in the first one. Withou spatial index it
must do 4,000,000 x 4,000,000 checks.
Spatial index is stored as tree of boxes, 6x8 bytes each, so 430 M is possible.
Brent Wood
