[GRASSLIST:5504] Restricting data summary to a specific area.
I have a map of parcel data in vector form and would like to restrict
my queries to a certain area. For example, in Arc View, I was able to
draw an outline around my area of interest and then extract information
for only those parcels contained in that area. Is there similar
functionality in GRASS? I don't have the money to buy ArcView, so that
isn't an option, but I really need to be able to do this.
I would really appreciate it if someone could point me in the right
direction.
Jason
OK, I have managed to use v.digit to draw the proper boundaries around
my area, but I have run into another problem. My intent was to use the
new vector file I created to cut the old vector file down to size. Well,
it isn't working. The use of v.cutter seems to work - at least it does
something - but when I try to display the new layer - nothing. Any
suggestions?
Jason
direction.
Jason
Hi to all
I need a quick help.....
I have this site file (in attach) , where the column starting with % is the
column of elevation...
I have to transform this file in vector format but using s.to.vect, I obtain
wrong results (I think because it use category values (#*) and not
attributes)
I would obtain a vector point file with elevations as categories (to patch it
with a vector contour file and interpolate the result)
I'm becoming crazy....
can someone help me???
Thank you very much???
ivan
Ivan Marchesini
University of Perugia
(attachments)
punti (7.89 KB)
On Mon, Feb 10, 2003 at 07:00:39PM +0100, Ivan Marchesini wrote:
Hi to all
attributes)
GRASS~> s.to.vect input=<name> output=<name> cat=decimal,1
echo ">gra.fcw@2ztr< eryyvZ .T pveR" | rot13 | reverse
Hi to all
I have another question
I have to export a vector grass file in dxf format...
grass exports ascii-dxf but autocad is not able to open it....
How can I export or transform ascii-dxf in binary dxf???
thank you very much!!!
Ivan
Ivan Marchesini
Thank you very much!!!!!
bye
Ivan
> Hi to all
> the column of elevation...
> obtain wrong results (I think because it use category values (#*) and not
> attributes)
Ivan Marchesini
see if qCad can open it:
http://www.qcad.org
"QCad is a free open-source 2D CAD system for Linux, various Unices and Windows."
and then resave whatever layers you need..
maybe in autocad "open as filetype" for an older autocad version? (8.x) ??
Could it be a problem with returns on different platforms? DXF is just a text file, but the text which GRASS exports will have unix returns (I suspect) while AutoCAD may expect a text file with Windows returns. You might open the dxf file in a text editor (I'm using a Mac and use BBEdit), check what kind of returns it has, and change to Windows if necessary; that might solve it.
I use Microstation on a Mac, and export dxf from that to import into GRASS; but it doesn't work if I don't open the dxf file and convert it to a unix text file first.
Nick Cahill
http://www.qcad.org
