[GRASSLIST:5514] Creating map: Simple way
I am looking for a very simple tutorial whcih just let me create a
simple map. [may be four points to represent a plot and two points to
represent trees]. I tried to search Internet, but I could not find any
that simple one.
Can someone help me?
Thanks in advance.
H.S.Rai
H.S.Rai
Alternate Email: hsrai@gmx.net
that simple one.
For simple map making, you might want to look at
Thuban
http://thuban.intevation.org/
or
Quantum GIS
http://qgis.org/
The latter also includes a plugin allowing it to access your GRASS data.
Moritz
On Tue, 25 Jan 2005 15:03:01 +0100 (CET), "Moritz Lennert"
Thuban http://thuban.intevation.org/ or
Quantum GIS http://qgis.org/
Thank you for your response. But my intention was to start
using GRASS, starting with a simple step. Is that possible?
H.S.Rai
H.S.Rai
Yes, obviously it is possible. Where are you at in the process at this stage ?
Do you already have GRASS installed ? If yes, which version ?
The easiest would probably be to use the display manager (d.m or d.dm
depending on the version) to put anything you want onto the map and then use
d.out.png to create a png image with the content of the screen.
In version 6.0beta you can also print directly from the display manager,
either to a printer or to pdf/ps/png file.
Moritz
