[GRASSLIST:5537] Problem compiling Grass 5.1 last version (08/02/2003)
Hi to all,
I have a problem trying to compile last version of Grass51
(08/02/2003)...
I use this configure parameters:
CFLAGS="-g -Wall" ./configure
--with-grass50=/home/rpms/GRASS/Sept2002/grass50_exp_2003_02_08
--with-gd-includes=/home/rpms/gd-1.8.4
--with-gd-libs=/home/rpms/gd-1.8.4
--with-postgres-includes=/usr/local/pgsql/include/
--with-opengl-includes=/usr/X11R6/include/
--with-opengl-libs=/usr/X11R6/lib --with-dbm
--with-dbm-includes=/home/rpms/gdbm-1.8.0 --with-dbm-libs=/usr/local/lib
--prefix=/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/dist.i686-pc-linux-gnu
--with-gdal
and there is no problem:
GRASS is now configured for i686-pc-linux-gnu
  Source directory: /home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08
  Build directory: /home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08
  Installation directory: /home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/dist.i686-pc-linux-gnu/grass5
  C compiler: gcc -g -Wall
  FORTRAN compiler:
  NVIZ: yes
  X11 support: yes
  DBM support: yes
  JPEG support: yes
  TIFF support: yes
  PNG support: yes
  GD support: yes
  Tcl/Tk support: yes
  PostgreSQL support: yes
  MySQL support: no
  OpenGL(R) support: yes
  ODBC support: yes
  FFTW support: yes
  BLAS support: no
  LAPACK support: no
  Motif support: no
  FreeType support: no
  GLw support: no
  NLS support: no
  Readline support: no
but I have this error:
gcc -g -Wall -Wall -I/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/include
-I/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/dist.i686-pc-linux-gnu/include
   -I/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/include -I/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/dist.i686-pc-linux-gnu/include
-I/usr/X11R6/include/ -I/usr/include/gr -I/usr/local/include -I/usr/include
-I/usr/local/pgsql/include/ -I/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/include
        -o OBJ.i686-pc-linux-gnu/open_ogr.o -c open_ogr.c
cc1: warning: changing search order for system directory "/usr/local/include"
cc1: warning: as it has already been specified as a non-system directory
cc1: warning: changing search order for system directory "/usr/include"
open_ogr.c: In function `V1_open_old_ogr':
open_ogr.c:37: structure has no member named `ogr'
open_ogr.c:44: structure has no member named `ogr'
open_ogr.c: At top level:
/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/include/gis.h:36: warning:
`GRASS_copyright' defined but not used
make[3]: *** [OBJ.i686-pc-linux-gnu/open_ogr.o] Error 1
make[3]: Leaving directory `/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/lib/vector/Vlib'
make[2]: *** [subdirs] Error 1
make[2]: Leaving directory `/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/lib/vector'
make[1]: *** [subdirs] Error 1
make[1]: Leaving directory `/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/lib'
make: *** [default] Error 1
I think there is a problem with #define HAVE_OGR...
Could someone help me?
Thank you
Mauro
________________________________________
Hai bisogno di una pausa? Vieni a giocare su Jumpy! http://giochi.jumpy.it
