I have all the required libraries installed (tiff, png, gd, ...). Sounds like
there may be library path issues.
Running d.where also had some troubles. When I issued the command, an endless
stream of coordinate were displayed until I made the 1st mouse click. Then the
command worked as it should (1 pair of coordinates per mouse click).
I'm going to recompile and write out the make output to a file.
Wayne Gibson
MIME-Version: 1.0
Content-Transfer-Encoding: 7bit
To: grasslist@baylor.edu
Subject: [GRASSLIST:5568] Re: GRASS 5.0.1 compilation issues
X-IMID: elron.baylor.edu
X-OriginalArrivalTime: 16 Feb 2003 18:16:36.0873 (UTC)
FILETIME=[8B29CF90:01C2D5E7]
X-Listprocessor-Version: 8.2.10/991025/16:55 -- ListProc(tm) by CREN
Andreas Lange wrote:
> I'm attempting to compile GRASS 5.0.1 on a SunBlade 1000. There are quite
a few
> "failed" messages in the config.log file. I assume that is normal. When I
> "make" the package, the only errors written to "error.log" are
> Compilation error in module: src/raster/r.tiff (ignored)
> Compilation error in module: src/display/devices/PNGdriver (ignored)You need to install tiff and png packages (from www.sunfreeware.com) for
the required libraries.He didn't report an error regarding r.{in,out}.png, so I suspect that
he has the PNG libraries, and it's the lack of the GD library which is
causing PNGdriver to fail.--
Wayne Gibson
Oregon State University
gibson@coas.oregonstate.edu
(541) 737-5696
