Sorry if this is inappropriate place to post this, but it was suggested I try here on qgis irc.
I have grass60.cvs (approximately one week old) compiled and functioning properly (so far from what I've been able to discern). I also have qgis 0.6.0 built from source with grass plugin enabled. Launching qgis from a shell (not inside grass) works fine until I try to load a Grass vector layer, where it crashes with...
error_routine (fatal = 1): GISRC - variable not set
Additional info. If I `export GISRC=~/.grassrc6`
..which looks like...
$ cat .grassrc6
GISDBASE: /home/jvarga/GISDATA
LOCATION_NAME: spearfish57
MAPSET: PERMANENT
GRASS_GUI: tcltk
...and then launch qgis from a shell, I get a (Qt/qgis) warning dialog that says...
"Cannot read current region: Is invalid line 1|: <-top: |->
(actually, I get this twice after clicking "ok" first time). I seem to still be able to load Grass raster data, but when I try to load grass vector data qqis crashes with (shell) error...
ERROR 1: libgrass: Cannot find vector archsites@PERMANENT
Lastly, if I load qgis from within grass shell, I get same Qt/Qgis warning dialog from above (Cannot read current region: Is invalid line 1|: <-top: |-> ).
Has anyone experienced this behavior? Is there something wrong in my .grassrc6 file? Where is the GISRC variable documented?
TIA,
Jack Varga
Most probably all the problems are caused by libgrass. libgrass and GRASS6 have different functions with the same names.
You have probably compiled gdal with libgrass and when the plugin in QGIS try to call a function from GRASS6 it actually ends up with old function from libgrass. You have to compile GDAL with GRASS6, i.e. use --with-grass instead of --with-libgrass.
This should solve
and
it will solve also
but you should know that region file in GRASS6 was extended to 3D
so you cannot read region files created in GRASS6 in GRASS5 or libgrass.
Radim
$ cat .grassrc6
MAPSET: PERMANENT
GRASS_GUI: tcltk
TIA,
Jack Varga
This SF.Net email is sponsored by: IntelliVIEW -- Interactive Reporting
Tool for open source databases. Create drag-&-drop reports. Save time
by over 75%! Publish reports on the web. Export to DOC, XLS, RTF, etc.
Download a FREE copy at http://www.intelliview.com/go/osdn_nl
Qgis-user mailing list
Qgis-user@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/qgis-user
