Hello all,
I'm trying to install mesa in order to run vis5d, but it conflicts with
xfreeGL. does anyone experienced this kind of problem?
thanks all.
Carlos Henrique Grohmann de Carvalho - Guano
Geologist - MSc Student at IGc-USP - Brazil
Linux User #89721 PGP key: www.keyserver.net
If you have a version of XFree86 which includes OpenGL, then you
shouldn't need to install Mesa.
d.zoom will not work unless a raster file name is provided. Why won't it
work with vector files only? This a is an inconvenience when importing
vector formats into a new location before converting them to raster.
Which version of GRASS? AFAIK, there was such a problem and it was
fixed. The problem was actually with d.vect (or whatever).
echo ">gra.fcw@2ztr< eryyvZ .T pveR" | rot13 | reverse
I am using Grass 5.0.0 from the command line on Solaris 8 Sparc. The
problem is that when you type in "d.zoom" the first prompt is:
Enter the name of an existing raster file
Enter 'list' for a list of existing raster files
Hit RETURN to cancel request
You cannot continue without entering a raster file name because it
interprets "RETURN" as cancel. Also, "d.zoom help" shows that "rast=name"
is manditory if you are not using the parser. Am I missing something?
----- Original Message -----
To: <GRASSLIST@baylor.edu>
Sent: Thursday, February 20, 2003 6:48 PM
Subject: [GRASSLIST:5615] Re: d.zoom with vector map
it
No, it's a problem with d.zoom, still present in CVS HEAD:
if(!rast && !vect && !site)
rmap->required = YES;
just->answer = 1;
The rast, vect and site variables correspond to whether any raster,
vector or site maps are currently displayed in the monitor (IOW, the
results of D_get_{cell,dig,site}_list()).
If no maps are displayed in the monitor, you have to specify the rast=
option, and -j is assumed.
IMO, most of d.zoom is bogus; it should just change the region then
re-run the command list. IOW, the interactive equivalent of
"g.region ... ; d.redraw".
Actually, it should probably just be subsumed into d.dm.
just->answer = 1;
I don't see that as such a problem. Maybe it should just exit an do
nothing in that case. With OP's mention of vectors, I assumed an older
version of d.vect was being used where there once were bugs regarding
setting the drawing command list so d.zoom wouldn't know about previous
d.vect commands...
Also I noticed that d.zoom does not work when I have a
rgb composite (using d.rgb) on the monitor. Is this an
old version problem (I still have pre5 installed)
Daniel
problem and it was
whatever).
CVS HEAD:
> just->answer = 1;
whether any raster,
monitor (IOW, the
just exit an do
I assumed an older
were bugs regarding
know about previous
d.vect commands...
reverse
__________________________________________________
Do you Yahoo!?
Yahoo! Tax Center - forms, calculators, tips, more
http://taxes.yahoo.com/
