I have done first exporting it from idrisi as GRASS format with the option ASCII.
And then importing into grass this file with r.in.ascii
Hope this helps
Marta
Hello,
I have IDRISI raster files (rst, rdc) and would like to import them into
GRASS. I already found a post from 1996 concerning r.out.idrisi/r.in.idrisi.
If this command was once created I assume it has been merged into r.in.gdal.
However the gdal raster format page does not list the IDRISI raster format.
Does anybody knows a work-around to import IDRISI raster formats into GRASS?
thanks, Martin
Mensaje enviado mediante una herramienta Webmail integrada en *El Rincon*:
------------->>>>>>>> https://rincon.uam.es <<<<<<<<--------------
Hi Marta,
thanks for your advice, I will do it the way you proposed if I can't find a
way to import IDRISI files directly.
I hoped that I could do it directly using a GRASS command (writing a script
for all files) due to the large number of raster files.
cheers Martin
On Wednesday 02 February 2005 11:12, marta.benito@uam.es wrote:
ASCII.
Hope this helps
Marta
> Hello,
> r.in.gdal. However the gdal raster format page does not list the IDRISI
> raster format.
> GRASS?
> thanks, Martin
Hallo,
what about exporting GRASS rastr from Idrisi? I have no experience with this,
but Idrisi (Kilimanjaro) seems, that it can do this.
Jáchym
On Wed, Feb 02, 2005 at 04:29:20PM -0500, Martin Wegmann wrote:
Hi Marta,
cheers Martin
> Hi,
> ASCII.
> Hope this helps
> Marta
> > Hello,
> > raster format.
> > GRASS?
> > thanks, Martin
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://www.fle.czu.cz/~jachym/gnupg_public_key/
