Dear Hamish, thank for your reply and the binary. I did not find in on the
grass homepage, and tried out to compile the source code. The other reason
was that I will use a mysql database, and the module to connect grass with
mysql was not available in the binary distribution. I compiled the uniodbc
with success and thought that I can do with grass the same thing...
Ok, thanks a lot for the binary. One problem, which I had was that d.m does
not start due to the missing of libgrass_gis.dll and libgarass_l.dll. In the
folder H:\cygwin\usr\local\grass6.0.cvs-i686-pc-cygwin-12_01_2005\lib, files
like "libgrass_D.6.0.cvs.dll" [70 kb] and "libgrass_D.dll" [1 kb] are
present. I changed the name from libgrass_gis.6.0.cvs.dll to
libgrass_gis.dll and libgrass_l.6.0.cvs.dll to libgrass_l.dll, and the
display manager works fine. In this folder are many other files like these.
Should I have to do the same with the others?
Unfortunately, when I start startx & window and type grass60, Grass
does not start and give the following messages:$grass60
Searching for web browser, but neither konqueror, nor mozilla, opera,
netscape found.
Cleaning up temporary files.
/usr/local/grass-6.0.cvs/etc/clean_temp: not found
Starting GRASS...
Error in startup script: couldn't read file
"/usr/local/grass-6.0.cvs/etc/gis_set.tcl": no such file or directory
Error in Tcl/Tk startup. If necessary, please report this error to the
GRASS developers.
Switch in to text mode now.
Hit return to continue...
/usr/local/grass-6.0.cvs/etc/set_data: not foundWhat could be wrong?
looks like none of the files made it into /usr/local/grass-6.0.cvs/etc/
what is in that directory?
did error.log report anything?
The error log say the following:
GRASS GIS compilation log
Started compilation: Wed Feb 2 03:01:29 2005
Errors in:
/grass-6.0.cvs_src_snapshot_2005_01_29/lib/gis
/grass-6.0.cvs_src_snapshot_2005_01_29/lib/gmath
/grass-6.0.cvs_src_snapshot_2005_01_29/lib/raster
/grass-6.0.cvs_src_snapshot_2005_01_29/lib/display
/grass-6.0.cvs_src_snapshot_2005_01_29/lib/D
/grass-6.0.cvs_src_snapshot_2005_01_29/lib/db/dbmi_base
grass-6.0.cvs_src_snapshot_2005_01_29/vector/v.external
/grass-6.0.cvs_src_snapshot_2005_01_29/visualization/nviz
Finished compilation: Wed Feb 2 03:54:45 2005
(In case of errors please change into the directory with error and run
'make')
I have followed the suggestions, but it does not help. Many folder were
empty after make install. Is it a special cygwin problem? I used CFLAGS="-g
-Wall" ./configure to configure and then just made and install.
Thank for the help, Jan
___________________________________________
Dr. Jan Bartholdy
University of Bonn
Institute of Paleontology
Nussallee 8
53115 Bonn
Germany
phone +49 0228 733336
fax +49 3301 808130
cellphone +49 172 3945713
email mailto@jan-bartholdy.de
____________
Virus checked by G DATA AntiVirusKit
