I am new to GIS and I like to borrow a data set from a person who uses
_ARC_GIS_8.3.
I have installed GRASS 5.7 on Linux. Data in which format I should seek
from ARC user, so that I can easily use it in GRASS 5.7.
H.S.Rai
Alternate Email: hsrai@gmx.net
(ie for vector data; for raster data you can load an Arc binary grid
into GRASS with r.in.gdal)
2. Open a NEW location in the 1st menu, just take XY coordinate
system, accept what ever prompts are give, for region.
3. U will find this file as a vector added to Ur dataset. IMPORT it
with '-o' in the command.
(with v.in.ogr)
I think it might be better to either create a new location of the
correct projection (if known) or use v.in.ogr or r.in.gdal with the
location= option to create a new location with the correct projection
parameters automatically (make sure shape files generate .prj!) rather
than leavcing it unset and overriding the projection check with -o.
You only have to do this once, best to get it correct at the beginning I
think.
4. Go to the GIS menu and set this vector as a region.
####[ GNU/Linux One Stanza Tip (LOST) ]#######################
Sub : Single user mode booting under grub LOST #266
To enter single user mode under grub, press "e" [edit] at the
grub boot menu and edit the boot parameters "kernel /vmlinuz
root=/dev/hdN single" (where N = your root partition)... Then
reboot using "b" [boot]... Easy ?
