[GRASSLIST:5674] real time gps tracking
Hello
I wonder if there is a module implemented in GRASS to see the actual position of a GPS connected to a notebook.
Can somebody tell me if there is a possibility to do real time tracking and with which module?
Thanks a lot, cheers Martin
Martin Wegmann
Department of Animal Ecology and Tropical Biology
Zoology III, Biocenter
Am Hubland
D-97074 Würzburg
Germany
E-Mail:
wegmann@biozentrum.uni-wuerzburg.de
m.wegmann@web.de
______________________________________________________________________________
Werden Sie kreativ! Bei WEB.DE FreeMail heisst es jetzt nicht nur schreiben,
sondern auch gestalten. http://freemail.web.de/features/?mc=021142
On Wed, Feb 26, 2003 at 01:06:45PM +0100, Martin Wegmann wrote:
GRASS is not really about realtime.
Try the GPS section on www.freegis.org to
see several software pieces to use readout GPS information.
Then there are others to visualise stuff.
You certainly also can add that information to GRASS maps
or use something like gpsdrive.
actual position of a GPS connected to a notebook. Can somebody
with which module?
position of a GPS connected to a notebook. Can somebody tell me if
Try:
gpsman - A GPS manager
gpsdrive - Car navigation system.
gpstrans - communicate with a Garmin Global Positioning System receiver
xastir - X Amateur Station Tracking and Information Reporting
for GRASS import:
s.in.garmin.sh
v.in.garmin.sh
(both require gpstrans)
You might be able to make a loop downloading the track and replacing the
vector file, but this would be terribly inefficient- it's a pity you
can't flush the track line with gpstrans. But parsing NMEA statements
realtime is the way to go, anyhow.
So try gpsman or gpsdrive instead, maybe with an exported raster map as
the backdrop.
H Bowman writes:
> Try:
http://pygps.org, too. Shows your position on any raster map with a
world file.
-russ nelson http://russnelson.com | A government does enough
Crynwr sells support for free software | PGPok | wrong to offset what it
521 Pleasant Valley Rd. | +1 315 268 1925 voice | does right. Better that
Potsdam, NY 13676-3213 | +1 315 268 9201 FAX | it should do less.
On Mac OSX, there's GPSys, too, which is a very good program.
On Wednesday, February 26, 2003, at 06:29 PM, Russell Nelson wrote:
H Bowman writes:
Try:
world file.
Think you mean GPSy (www.gpsy.com).
Unfortunately, it's not free software.
H Bowman writes:
Try:
world file.
There is a software called FlightTrack for Mac OS. It is a freeware http://flighttrack.sourceforge.net/
Maybe it can do what you want.
H Bowman writes:
Try:
world file.
