On Tue, 8 Feb 2005, Steven T.Stoddard wrote:
I am using GRASS 5.7 and R 2.0 for OS X. I have a simple xy location I
am doing some theoretical work with and would like to import maps into
R using the interface in order to do analyses. Yet when I attempt to
do this, I get the following error:>G<-gmeta()
Error in gmeta() : region for current mapset is invalid
line 11: <top: 100>
run "g.region"I traced the problem to the compiled C program that is called from the
gmeta R function (i.e. > .C("gmeta") gives me the same error). I
haven't been able to locate the source code on my volume.If I use gmeta(interp = TRUE) there is no problem, until I want to
actually try and import data from my locations.
The current fix for 5.7 and 6.0.0beta is to use interp=TRUE. The cause of
the problem seems to be the use of the 3D WINDOW, which the older code in
the R-GRASS interface doesn't yet honour. I'm not at all sure what will
happen if your x,y locations are sites; the interface knows about
old-style sites, not vector sites. You may be obliged to use system("") to
issue GRASS 5.7 commands to write out an ASCII file to read into R with
read.table().
Roger
Any help is appreciated.
Steve
Steven T. StoddardProgram in Ecology, Evolution and Conservation Biology
University of Illinois at Urbana-Champaign(217) 333-2235
302 Shelford Vivarium
606 E. Healy Ave
Champaign, IL 61820
http://www.life.uiuc.edu/~sstoddar
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand@nhh.no
