[GRASSLIST:5688] Re: GRASS in old hardware
hi to everyone too!
follow-up question on this. i just would like to know which linux distribution
best suit the grass60. i am a newbie and uses the binaries for installation.
i was planning to use fedora core 2 but learned from previous mails it's not a
good match.
thank you,
november a. romena
Hi GRASS users:
I want to know which is the smallest hardware configuration that
a full GRASS is installed.
Which LINUX distribution is better to support GRASS on a small
and old hardware configuration for example a 486 procesor with 64 MB?
Thank you for your help.
Kenneth Cabrera
distribution best suit the grass60. i am a newbie and uses the
it's not a good match.
From source code: pretty much anything will work, see REQUIREMENTS.html
  to make sure all needed packages are installed.
From 6.0 binaries: SuSE 9.1 and DebianGIS are already packaged.
  http://grass.ibiblio.org/download/index.php
I can give instructions on how to compile on Fedora if needed, as long
as you have the recipe it isn't too hard. I expect there will be new 6.0
Fedora binaries before too long ....
Hamish
