[GRASSLIST:5689] Sorry, no access to <<PERMANENT>>.
…bout ready to pull my hair out on this one.
Bottom line: Why does grass deny access to everyone except the owner of the PERMANENT mapset??
Background:
Trying to work with the demo data provided with GRASS (global and spearfish). The data are stored on my disk as follows
/home/grass_data
|- global/
| |- PERMANENT/
| |- grasslinksX/ : other mapsets
|- spearfish/
| |- PERMANENT/
User X installed the data so user X owns all the files that were placed in the DATABASE (/home/grass_data). User X wants to share his mapsets with everyone so user X foolishly gives read/write access to the world on every file in the database (chmod –R 777 /home/grass_data).
User Y would like to read the GRASS database setup by user X. GRASS denys access to user Y with the following message:
Sorry, no access to <>.
Mapsets in location
grasslinks0 grasslinks1 grasslinks2
grasslinks3 PERMANENT
note: you do not have access to any of these mapsets
Hit RETURN →
No matter what (yes I’ve tried g.access) GRASS will not allow anyone but the owner to access PERMANENT. This flies in the face of the documentation.
Any comments on this behavior?
Md
PS. Here’s the kicker, in my scenario, user Y is ….root. Hmmm, when root can’t do it, something’s not right!!! (also tried others as “user Y” and got the same thing).
PPS. Same behavior in grass4.3 and grass5.0.1.
Matt Doggett
Spatial Climate Analysis Service
Oregon State University
316 Strand Ag Hall
Corvallis, OR 97331
(541)737-9153
mdoggett@coas.oregonstate.edu
Matt Doggett wrote:
.bout ready to pull my hair out on this one.
Bottom line: Why does grass deny access to *everyone* except the owner
At the implementation level, the reason is:
  * G__mapset_permissions (mapset)
  * returns: 1 mapset exists, and user has permission
  * 0 mapset exists, BUT user denied permission
  * -1 mapset does not exist
  int G__mapset_permissions (char *mapset)
      char path[256];
      struct stat info;
      G__file_name (path,"","",mapset);
      if (stat (path, &info) != 0)
        return -1;
      if (info.st_uid != getuid())
        return 0;
      if (info.st_uid != geteuid())
        return 0;
      return 1;
At a design level, the reason is ... well, your guess is as probably
as good as anyone else's. Whoever originally implemented this
presumably had their reasons, but I doubt that any of the current
developers would be able to justify it.
