[GRASSLIST:5713] Re: Unrectified DXF importation
Dear Markus
Thanks for the tips and explaination. It works now after
I insert the -r option in the v.transform.
Firuz
On Fri, Feb 28, 2003 at 03:42:09PM +0800, Dr. Mohamad Firuz Ramli wrote:
Dear list
Thanks to Sandro for helping me in my first problems
with dxf data.
I have another problems.
I try to import unrectified dxf layer. I manage to do it.
However when I did the transformation using v. transform,
it shows the transformation process with the residual value.
But when I tried to display the rectified dxf. It did not show anything.
I followed the procedure in Neteler and Mitasova’s book but I encounter
a problem such as above.
This is the procedure that I did.
v.in.dxf -a dxf=vmap.dxf prefix=vmap --to import dxf data into ascii
I want to import road layer inside vmap
v.in.ascii in=vmap.road out=vmap_roadxy
v.support vmap_roadxy
g.region -p vect=vmap_roadxy
d.erase
d.vect vmap_roadxy
I managed to display the vmap_roadxy layer on the screen and identify four gcpoints
in x and y coordinates and its location on the map for the real coordinates and
save in in ASCII table point as roadgcp
Up to now the map name is “vmap_roadxy”, right?
After that
v.transform in=vmap_road out=vmap_roadtrans point=roadgcp (as in Neteler and Mitasova book)
ERROR:Could not find input vector vmap_road
Yes, because the name was wrong.
v.transform reads binary vectors only:
" v.transform - Transforms an binary vector map layer from one
coordinate system into another coordinate system."
i.e. the result of v.in.ascii.
After that I change the input to the one that I convert to binary file
v.transform in=vmap_roadxy out=vmap_roadtrans point=roadgcp
Looks better…
The map is transformed with the residual value
Transformation is complete
v.support vmap_roadtrans
Here it may help to use
v.support -r vmap_roadtrans
[should we make “-r” a default?]
g.region -p vect=vmap_roadtrans
Now hopefully shows the correct boundary coordinates.
Markus Neteler
