[GRASSLIST:5715] Problem with GRASS
Hi GRASS users
I have a problem. I am running off of MAC OS 10.2.4. Suddenly I can’t use grass any more. I get the following when I try to start up:
[Kurt-Springss-Computer:~] kurtsprings% grass5
Starting GRASS …
Error in startup script: can’t read “env_locations”: no such varialbe
while executing
“set location $env_location”
(procedure “searchGISRC” line 23)
invoke from within
“searchGISRC $gisrc_name”
(file “/usr/local/grass5/tcltkgrass/script/gis_set.tcl” line 1)
ERROR: LOCATION_NAME not set
/usr/local/grass5/ect/Init.sh: GISBASE: parameter null or not set
I have been having problems with crashes all weekend and was wondering if a UNIX system file in OS X might have been corrupted.
The first time I started out, it started fine until I tried to create a new location. The error above, or something like it was the result. Now, this is all that I can get. I if some one knows a simple solution, I am all ears. Otherwise, I was going to take drastic action and reinstall OS X, wipe out the hard disk, and start over.
If I don’t have to do this, I will be very happy.
I am for bed now. I hope someone can give me good news before I start in the morning.
Sincerely
Kurt D. Springs
Kurt Springs wrote:
I have a problem. I am running off of MAC OS 10.2.4. Suddenly I can¹t use
Starting GRASS ...
Error in startup script: can't read "env_locations": no such varialbe
    while executing
"set location $env_location"
    (procedure "searchGISRC" line 23)
    invoke from within
"searchGISRC $gisrc_name"
    (file "/usr/local/grass5/tcltkgrass/script/gis_set.tcl" line 1)
Delete the file ~/.grassrc5 (e.g. "rm ~/.grassrc5") and try again.
BTW, some other persistent tcltkgrass errors can be fixed by deleting
the file ~/.tcltkgrass.
