[GRASSLIST:5721] Doubts in ./configure
Hi;
I'm installing GRASS5.0.0pre5 and I've got some doubts:
First of all. I see that there is an option for compilling against gdal. I've
installed gdal from precompiled binaries, and I write
--with-gdal=/usr/local/bin ; but a message appears telling me that I've not
chosen to
compile against gdal. Why?
Is it necessary to use this option to use gdal?
The other problem is that the following message appears:
checking for dnrm2_ in -lblas... no
configure: error: *** Unable to locate BLAS library.
I've found 'dnrm2_' in libblas.so.3, but I haven't got a libblas.a. Could I
chose this lib instead of libblas.a? How? A similar thing occurs with lapack.
Thanks and regards.
Javier
pre5 is quite dated; the latest version is 5.0.1.
chosen to
If you specify an argument to --with-gdal, it should be the complete
pathname of the gdal-config script, e.g.
  --with-gdal=/usr/local/bin/gdal-config
Alternatively, you can just use --with-gdal (without a value).
No. The --with-gdal switch forces r.in.gdal to be linked directly
against libgdal at compile time. Without that switch, r.in.gdal will
load libgdal dynamically (like a "plug-in").
Currently, the BLAS and LAPACK libraries aren't actually used by
anything (more precisely, they are used by a couple of functions which
aren't actually used).
As for why the test fails: look in config.log for any error messages
related to libblas.
