[GRASSLIST:5757] Add location name to GIS Manager window name and to shell prompt
Hi
Grass 6.0 is multisession and now it’s possible to open more locations but all windows and the prompt have the same name and it’s difficult to navigate between the windows.
It’s useful to change these rows:
lib/init/init.sh
row 625
  • echo “GRASS GRASS_VERSION_NUMBER > '” >> “$cshrc”
  • echo “GRASS GRASS_VERSION_NUMBER - $LOCATION_NAME > '” >> “$cshrc”
row 667
  • echo “PS1='GRASS GRASS_VERSION_NUMBER:\w > '” >> “$bashrc”
  • echo “PS1='GRASS GRASS_VERSION_NUMBER:\w - $LOCATION_NAME > '” >> “$bashrc”
display/d.m/d.m.tcl
row 205
proc Dm::_create_intro { } {
global dmpath
global GRASSVERSION
  • global location_name
variable max_prgindic
set top [toplevel .intro -relief raised -borderwidth 2]
wm withdraw $top
wm overrideredirect $top 1
set ximg [label $top.x -image [image create photo -file “$dmpath/intro.gif”] ]
set frame [frame $ximg.f -background white]
  • set lab1 [label $frame.lab1 -text “GRASS $GRASSVERSION GIS Manager” \
  • set lab1 [label $frame.lab1 -text “GRASS $GRASSVERSION GIS Manager - $location_name” \
row 846
proc main {argc argv} {
global auto_path
global GRASSVERSION
wm withdraw .
  • wm title . [G_msg “GRASS $GRASSVERSION GIS Manager”]
  • wm title . [G_msg “GRASS $GRASSVERSION GIS Manager - $location_name”]
Also it’s useful to add the location name to x0 (x1,x2,etc.) monitor name in display/drivers/XDRIVER/XDRIVER24/Graph_Set.c
Bye
|| Lorenzo Moretti e-mail: lorenzo.moretti@bologna.enea.it
||/|/| ENEA prot/idr Web: http://wwwamb.bologna.enea.it/
|| | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/ (ris.)
________________________________________________________________________
On Mon, Feb 14, 2005 at 10:44:41AM +0100, Lorenzo Moretti wrote:
Hi
Grass 6.0 is multisession and now it's possible to open more
locations but all windows and the prompt have the same name and it's
It's useful to change these rows:
lib/init/init.sh
row 625
- echo "GRASS GRASS_VERSION_NUMBER > '" >> "$cshrc"
+ echo "GRASS GRASS_VERSION_NUMBER - $LOCATION_NAME > '" >> "$cshrc"
row 667
- echo "PS1='GRASS GRASS_VERSION_NUMBER:\w > '" >> "$bashrc"
+ echo "PS1='GRASS GRASS_VERSION_NUMBER:\w - $LOCATION_NAME > '" >>
"$bashrc"
Then the prompt will become rather long, right?
display/d.m/d.m.tcl
row 205
    global dmpath
    global GRASSVERSION
+ global location_name
    wm withdraw $top
"$dmpath/intro.gif"] ]
- set lab1 [label $frame.lab1 -text "GRASS $GRASSVERSION GIS Manager" \
+ set lab1 [label $frame.lab1 -text "GRASS $GRASSVERSION GIS
Manager - $location_name" \
row 846
    global auto_path
    global GRASSVERSION
    wm withdraw .
- wm title . [G_msg "GRASS $GRASSVERSION GIS Manager"]
+ wm title . [G_msg "GRASS $GRASSVERSION GIS Manager - $location_name"]
This one I'll leave to Michael.
Also it's useful to add the location name to x0 (x1,x2,etc.) monitor
Done.
Hi Markus
Hi
lib/init/init.sh
row 625
row 667
"$bashrc"
Not too much. Example:
GRASS 6.0.cvs - spearfish57 >
Or if too much long an idea
G6cvs-spearfish57 >
G6000-spearfish57 >
It's important to see what is the location in Grass 6.
in daily work it's very useful because with Grass 6 is more easy to work with 2, 3 or more locations together and the shell has always the same name: this was not a problem in Grass 5.x with 1 location any time.
display/d.m/d.m.tcl
row 205
     global dmpath
     global GRASSVERSION
     wm withdraw $top
row 846
     global auto_path
     global GRASSVERSION
     wm withdraw .
Ok I'll send the changes to Michael
Done.
Good, very useful
Bye and thanx
|| Lorenzo Moretti e-mail: lorenzo.moretti@bologna.enea.it ||/|/| ENEA prot/idr Web: http://wwwamb.bologna.enea.it/ || | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/ (ris.)
~~~~~~ 40128 BOLOGNA - ITALY Ph: +39-0516098086 Fax: +39-0516098131
On Tue, Mar 01, 2005 at 10:10:11AM +0100, Lorenzo Moretti wrote:
Hi Markus
>> Hi
>> lib/init/init.sh
>> row 625
>> row 667
>> "$bashrc"
G6cvs-spearfish57 >
G6000-spearfish57 >
any time.
I see. What about this:
GRASS 6.0.cvs(brdUTM33):~ >
                     location
added to CVS.
PS: Please send diffs always as attachment, not inline.
> >it's > difficult to navigate between the windows.
> >> lib/init/init.sh
> >> row 625
> >"$cshrc" >
> >> row 667
> >'" >> > "$bashrc"
> G6cvs-spearfish57 >
> G6000-spearfish57 >
> any time.
                     location
If you are going to do that, would it be more logical/possible to do
GRASS x.y.x(location:mapset):\W >
does this get updated when you use g.mapset to change
location/mapset/database? (like adding a MASK changes the prompt)
Personally I like simple & elegant:
GRASS 6:~ >
\W instead of \w uses just the top dir name, not the full path. You can
see where you are but with a much shorter prompt.
And so my ~/.grass.bashrc file includes the line
PS1="GRASS 6:\W > "
Hamish
Hi Markus
                     location
added to CVS.
Ok for me. Mapset is less important now: it's a long name
Ok only an attachment.
Bye
